7,737
434
Posts: 8,216 Likes: 235
I had a bloke yesterday wanting a Powertorque motor for his slasher that had broken the end off the crank. I wasn't sure if these use the standard PT motor or the longer shaft Tornado type. My guess is because they were produced way before the Tornados came out I think they use the shorter shaft. He is going to bring it here for me to fix but I would like to have an idea what I am up against first. I have a 550 here with a full crank motor but it is stacked away so a bit difficult to get to to see if that runs the same shaft as the standard full crank. Anybody have any ideas? Sorry I just remembered I fitted a full crank side pull to a 550 LRT brought here for me to fix a couple of years ago, so seeing a standard full crank fits I would assume a standard length PT should fit? Then again there is the option with the full crank of using spacers to raise or lower the motor so I'm not sure again.
Posts: 4,675 Likes: 165
Why did the Tornado employ a longer shaft ? Just the style of body required it?
MF I guess it was so they could put a Briggs on them as well without using a spacer ring and seeing they were designing a new body they could make it look bigger than the normal Victa base and then they were able to make it a 19 inch cut which was another selling point I guess.
Does this mean you can fit these PTs to a Rover or Masport base then?
MF haven't looked at that option, probably still have problems with the height adjuster bar, but these Tornado motors are few and far between. I picked up a good one last week in the piles of stuff I got from a bloke who had given up fixing Victas. He had fitted a Tornado motor on a standard base, great idea except the blades were sitting 20mm below the base skirt. Good chance for somebody to chop their toes off
Posts106,871
Members18,214
