1 members (AussieHJ), 838 guests, and 1,796 robots.
Masport Shitemaster 720 blade
We have a Victa 2 Stroke Tilt-A-Cut Power Edger with S90 Engine Pack. Back in August 2015, I asked for guidance with the Pulley Belt as it had broken. Your support and replies to my questions that you gave, were amazing. Hey, it’s great knowing where to go, to get the right advice and support. I’m now needing more assistance with this Edger, and looking at your Forums, I noticed a situation that sounds the same as ours, it was from QSR, Dated 27th October, 2013. Our Edger starts after a couple of pulls, but then it starts blowing a lot of white smoke, it runs for about 10 to 15 seconds, and then it cuts out. Prior to starting the Edger, I had removed the Spark Plug, which was clean, made sure there was very little fuel in the tank, and then we turned the Edger on its side (Spark Plug side facing the ground) to check the Pulley Belt and Cutting Blade. Shortly after, I noticed a dark thick oily looking liquid, very slowly dripping, and it seemed to be coming from where the Spark Plug is inserted. I’ve wiped out the internal area where the Spark Plug is inserted, ensured that everything was ready so I could restart the Edger again, but the same situation occurred, a lot of white smoke, and cuts out after 10-15 seconds. When this occurred again, I rechecked the Spark Plug and it was slightly damp with that dark oily looking liquid. I haven’t tried to pull anything apart, as I would need to see a Manual for the S90 Tilt-A-Cut Edger. I’m pretty sure that I need a new Gasket for the Victa Tilta-A-Cut S90. O Rings were also suggested, but I need to know the parts number for this item and I’ll also need to find the Manual for this Edger. I would appreciate your comments. Thanks again.
Hi Sherrie, my first thoughts are the fuel tap has been left on but the fact that you can get it to even start. My first thing would be to get one of these float needles, www.ebay.com.au/itm/Carburetor-needle-suits-Victa-2-stroke-engines-G4-LM-carbies-CR03404A/112772632612 don't waste your time with any others, they don't work. The fact you have oily stuff coming from the plug hole indicates the fuel has been left on, float needle has not sealed, fuel has flowed into the crank case and then the petrol has evaporated, leaving just the oil. You may have to leave the plug out and keep pulling it over to clear the fuel/oil from the crank. If after you have done this and you still have no joy you may have to follow the steps I have detailed in the G4 carby modifications here in this forum. See how you get on and let us know.
Hi NormK I'm a novice when it comes to this. I've got a lot to learn about motors, but I'll definitely check this out and the supplied link. I sincerely appreciate your time and this information. Thank you !!! I'll be back.
Sherrie, while the carby modifications seem a little daunting if you go through the process step by step you will be pleasantly pleased with the end result and your Tilt a Cut will be a pleasure to use
Hi NormK, I've been trying to locate the Carby modifications you mention, but I haven't found it as yet, but I've read a lot of your postings, very good reading and some are quite funny. I've located a Manual for the Tilt-A-Cut, on this Website, but haven't had a chance to have a look at it as yet. Thanks again for your time.
Hi Sherrie, this is the modifications they are almost identical but the G4 needs a couple of little extra things done to it. Read through it and if you have any questions just ask.
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/82288/g4-lm-carby-repair-modifications.html#Post82288
Hi NormK, Thanks for the Link - I'll check it out. Have a great day!
Hi NormK, Gee that's a feat in itself. I've got to work out how to get to fit the Calibrator Needle and where it goes. I know that sounds funny, but I've never had anything to do with motors before. I'll let you know how I go. Thanks again
One thing I forgot Sherrie is when you replace the float needle you should replace the "O" ring as well or it will probably leak. Easy five min job but just go steady and ask if you are not sure.
Hi NormK Again, thanks for your reply. I've worked out where the Calibrator Needle is situated. I've unscrewed the screw that secures the outer Cap. That screw has a filter as part of that screw... a very interesting filter, but you would know about that. I can see the Float, the 'O' Ring and the little Calibrator Needle. I'll purchase all the parts that you have suggested, and I it's the way to go. We've had major Internet issues, and I think that this is due to the local 2018 Commonwealth Games and all the infrastructure that has had to be put in place for the Games, but this has been been going on and off for months and months. I've got good connection at this stage. Thanks NormK, and when I get the replacement parts as you have recommended, I'll be back in contact, but I'll continue to check this forum.
Ok Sherrie, so far so good, with the screw/main jet and filter, put the filter up to the light, holding the screw end in your fingers and rotate it slowly and at a certain point you should be able to see through the filter, if not blow in through the small end and check again to see if the filter is clear. The next step once you get the new needle is to make sure the float will work properly to seat the needle, some primer caps are a problem, but we can work through that.
Hi NormK I'm back. We also have a Victa Lawn Mower, and I had just noticed that the Primer Bulb had split on the Mower, so I removed the Primer Bulb/Cap, from the Lawn Edger (Tilt-A-Cut) and put it on the Lawn Mower. ( Lawn mower filter had dislodged, and was blocked, which I didn't realise...all good now, thanks to you! ) It's great to have this knowledge. Back to the Lawn Edger, we tried the Needle Pin (brass looking) that came with the new Primer Bulb and Cap that we had purchased for the Lawn Mower, but we still have an issue. The Spark Plug is oiling up. Each time, we've removed the Spark Plug, cleaned it, and replaced it, then it starts, but the white smoke is still occurring and she stops after about 10-15 seconds. I'm not sure how I can confirm that I've cleaned the internal area where the Spark Plug is inserted to ensure that there is no oil residue left, can you kindly advise. Many thanks again for your time and guidance.
Try tilting the mower about 45� in the direction the spark plug faces and pull the engine over briskly a handful of times to try and purge the bore of any excess fuel before putting the plug back in. Quickly wipe the spark plug hole as well, before putting plug back in.
Hi Mowerfreak, Many thanks for your reply. When I do this, I'm assuming that the Fuel would be turned off, I know that may sound an odd question, and your reply would be appreciated. Thank you.
Hi Sherrie, yes fuel turned off and keep pulling it over with the plug out and then put the plug back in and try again, eventually it will clear it and then it should start. The problem is the fuel was left turned on and the crappy Victa needles are not to be relied on to stop the fuel flowing and then it ends up in the crankcase. The new needle will prevent this happening again
Hi NormK Thanks for your reply, and thanks to Mowerfreak also. NormK, confirmation of turning the fuel off, I know sounded like an unusual question, but when a person doesn't know, the question has to be asked when a novis tries to work out what to do. All this information and communication is amazing. I'll do this tomorrow, and as you mentioned the Brass Needle, I'll take that out of the Lawn Mower (new Primer Bulb/Cap and Brass Needle) and give it another go, and get rid of the excess fuel that Mowerfreak had mentioned. Thank you to both of you... it's sincerely appreciated. I'll let you know how I go. Take care...
Hi Sherrie, most certainly best to have throttle off and tap off as Norm K said. Anything to restrict fuel flow is a good step here. It's a good habit to make sure the fuel tap is off before putting the Victa to bed, as leavingfuel flow on can flood the engine as it sits in storage.
H Mowerfreak, I'm pretty sure that the fuel tap has been turned off after each time it's been used, but then sometimes people don't realise that they may not have done this, but I'll ensure that this happens in the future. Hopefully tomorrow when I have another got at getting the Edger going, it will keep going. I'll log back in and update the outcome. Kindest regards to you and NormK
Hello NormK and Mowerfreak, ' WE HAVE SUCCESS ' - NormK, we used the Metal Pin that you had recommended and this definitely made a difference, along with the information given by Mowerfreak. We had the Tilt-A-Cut Edger tilted on its side (spark plug side down and had removed the spark plug). We left the Edger like that for about 36 hours, and a small amount of oil did drip out of the area where the spark plug is inserted. Wiping the inner thread where the plug goes and cleaning up the spark plug again, we attempted to start the Edger - white smoke engulfed the area and the Edger ran for about 15 seconds. Repeating the cleaning of the inner thread, and the spark plug again on another 2 occasions and then we had success. The Edger kept running, no smoke, running a bit rough, but then it sorted itself out and 'it's like a bought one' as they say. Thank you to both of you, for sharing your knowledge and time. Take care, Kindest regards to you and yours.
NormK and Mowerfreak, I forgot to ask a question about the fuel side of the 2 Stoke Engines. I remember my dear Dad always saying that you should always 'turn the fuel off and let the motor run until it stops by itself'. Knowing your experience, would you say that this would still be the case, or is it better to turn the fuel off and stop the engine? I would appreciate knowing the better way to look after both our Lawn Mower and the Edger in the future. Thanks again. Sherrie.
Hi Sherrie, your call doesn't seem to make a lot of difference, turning the fuel of before stopping, what that does is it gets you in a routine of turning the fuel off. Now that you have a needle that actually shuts the fuel off I(something Victa was never able to achieve because they cheaped out with the rubbish plastic needle) you now have a much better chance of not getting caught again with a flooded motor .If you had come here six months ago we could not have offered you the new needle, you would have had to buy 10 of the plastic rubbish and hope you got one that would work. I started modifying Briggs and Stratton needles, these were better than the Victa but were still a bit problematic but these new viton tipped ones are brilliant.
Hi Sherrie. It's a shame others would write the machine off and go hunting for a cheap new four stroke replacement that will fail in months. You have the best mower engine in the world and have now made it even better through research and making enquiries through the miracle of the internet. NormK in particular has further cemented my faith in the Victa two stroke and it's performance and durability. It's so tragic to think how many of these fine Aussie machines have been needlessly disposed of due to a tiny part like a plastic needle and the false perception that four strokes are the only way to go. Nothing is as robust and gutsy as the loud and sporty two!
Hi NormK - you've got no idea how pleased we were when she kept going, it's so good. Thanks for your reply regarding the fuel, that's good, as I wanted to get it right, so now, I know. Thanks again.
Hi Mowerfreak, Hey you're not wrong. Last Wednesday, we came across exactly the situation that you are talking about. Owners of a 2 stroke, had had it for years, it always went well, then it stopped working, so they purchased another mower. At that stage we were just learning and gaining the knowledge on how to get our Edger going. I really enjoyed reading your message, and having the reassurance that the 2 Stroke was so worthwhile. NormK, yes he's a wealth of knowledge, and it's so pleasurable to know that like you, and NormK, there are people out there that are willing to help. Mentioning the Internet, this may sound odd, but I had to check out Youtube, to then work out where the Carbi was located and how it worked, and then I spotted the Needle, and as they said on Youtube, to correctly place it, the Needle has to be placed pointy end down. Don't you love the Internet !! I agree, it's amazing what we can all learn. I've just posted a new Thread, about our Chainsaw, so hopefully I'll be about to work through this question also. Thanks again for your support.
18,062 Registered Users
Topics12,746
Posts106,765
Members18,062
