1 members (nath), 10,235 guests, and 461 robots.
Engine number is 95902 0107 01 92129. The last couple of numbers may be wrong. Anyway it is a "sprint" type engine and is blowing white smoke and oil out of the exhaust but it gets worse. The oil is also finding its way back into the carburetor via the return gas/fuel line. There is oil in the valve chest too. Does this mean rings, exhaust valve or PCV valve? Grateful for advice.
The engine is probably kaput anyway but I will try replacing the PCV valve as that's easy to do and see if it makes a difference.
Any ideas guys?
I replaced the PCV valve. I can see oil leaking from the bottom of it soon after I turn it off. Tried another one-same thing. Gasket looks OK. I have applied some gasket maker to see if it makes a difference. I can't see any leak until I turn the mower off but it must be going back into the carby while it is running.
Seems to have fixed it! I can't believe I've actually fixed something.
Hello Sparker
Folks often forget about crankcase compression issues.
I feel the tappet flapper valve was a good choice, given the white smoke.
It is rewarding when something is fixed.
I feel the vital clue here was white smoke.
I hope your posts helps others.
There is actually several ways this can happen. The breather is one. The question on the oil the lifter to valve area though. It is supposed to be a little oil in there but it should not be overflowing ie standing oil. If so then the crankcase is overfilled. Usually can tell as the drain back hole will be pumping out oil.
As other sources of the blowby beside the rings there is the valve guides of which the exhaust is the culprit. When worn out can smoke like a freight train. I had customers comes wanting the rings replaced when it was only a valve guide problem. Now of course I install a new valve too.
Also there is the head gasket as it can blow or because of a warp head allow compression gases to re-enter the crankcase via the head bolts as some of them go all the way through into crankcase.
Just a few additional thoughts though it sounds like Sparker has luck out on this one.
18,241 Registered Users
Topics12,778
Posts106,882
Members18,242
