0 members (), 5,661 guests, and 591 robots.
#89284 19/12/17 12:27 PM
Hi,
As the title suggests I�m having issues with throttle control. Recently snapping the throttle cable didn�t help but even once a temp repair was made, any form of throttle applied will kill the engine.
The diaphragm was replaced and some carby cleaner used, however it has always chased it�s revs when in use.
The governor spring was also replaced but doesn�t seem to have much control over the throttle above the carby at all.
I was told it�s an issue with the carby which I�d like to replace completely and keep it genuine or would I be better off completely replacing the motor?
Thanks,
Reece
what is the type number?
80202 23240-1 87092103
080202-2324-01 Air vane governor setup.
On these engines the fuel tanks tends to rust. This rust can enter the carburetor main tower and clog the metering passages causing lean burn that sounds like you're experiencing. It would take someone with the experience of removing and replacing the steel balls to clean out these passages. Since most don't have this knowledge it is best just to replace the carburetor, add the filter screen below, and if need the fuel tank.
This problem of clogging could have been prevented if only the setup had the 691213 filter screen in place with but according to the IPL this engine wasn't setup with the screen installed. This still doesn't resolved the problem of the fuel tanks rusting.
That�s great information thanks.
Do you happen to have a link for said carby as I�ve searched high and low but can�t seem to locate the correct items.
Thanks again
Hello Reece and AVB
Reece, AVB is a Senior Technician on Briggs.
He certainly knows his stuff!
I do know that, on these old Briggs, any wear in the throttle butterfly shaft
may cause these symptoms. Any manual moving (by hand) of the throttle shaft should be able to
check engine response - being related to the carby, or external things - carby gasket, filter,
gov spring ...
I attach a modern manual for your Model and Type.
18,185 Registered Users
Posts106,825
Members18,185
