1 members (MarkusB), 3,906 guests, and 2,113 robots.
Hi. I came across this mower with a slight price reduction from $399 to $349. Seems like a good buy.
It's features are:
Large 196cc OHV engine (Likely Chonda)
21" cutting width.
Key start using Aldi's in house power tool battery (supplied).
Variable speed self propelled system
Twin cup holders on the handles!
Mulch, catch in hard catcher or side discharge.
Soft handlebar grips.
Four swing back blades.
Washing hose port.
I reckon this thing is amazing value and looks to be well constructed. My main reservations are where to obtain blades and the reliability of the self propelled system. Looks like a nice prospect for the domestic user who is observant on keeping the oils up to their mowers and who never uses E10 (like me!). See below.
I have a couple of the bigger Gardenline mowers here at the moment, have had a few over the time, hardly a mark on them so they have obviously done little work but they get thrown out because they are a mongrel to start obviously. Pretty false economy buying that sort of stuff, it is cheap for one reason. A quick squirt of aerostart will fire them up but most people can't be bothered with pulling the air filter cover off
No, no no, cheap and nasty!
Had a bloke bring a small one here a couple of days ago he bought it new and only got to use it once, next time he went to use it he couldn't get it started. My pile of Chonda motors is getting quite high, most have done little work, but the common denominator with these is rusty carbys
And another thing with the bigger Gardenline mowers, not sure about the self propelled but the ones I have had dealings with, the catcher is so flimsy and such a bizare attaching method that I have only seen one, obviously they float away in a stiff breeze. On a few I rivet on a Victa rear flap and then you can use a standard Victa catcher, works fine
You aren't mixing it up with the similar sounding Gardener's Choice NK? Can a Victa Powertorque be made to work on either, shaft length wise?
Hi MF you are right the bigger ones are Gardeners Choice, still just as much trouble. I just had another little Gardenline dropped off here, the pile of these hardly used machines is getting bigger by the day. As for fitting Powertorques to them you have the same issue, shaft is 20mm too short. Also had a little side throw Victa slasher left here to get back up into working condition again. Getting a little out of control, for every mower I get rid of 2 more arrive
Someone like the carby master should work on an aftermarket bolt on extender kit for the shaft. It would be a hit IMO if you advertised that it will allow you to bolt a Victa two stroke onto other bases with relative ease.
He seems to have solved the archilles heel of bad needles, now to expand the options for bases to mount them on.
I wouldn't go messing with the design on that part of the crank when it is spinning so hard with a lump of metal hanging on the end of it. I doubt too many people would bother swapping a powertorque onto other bases, I have done a few for various reasons but making up spacers for the 4 mounting hole under the carb is a real pain
You are right there. I just thought of whether you could do that, but yep, not a good idea to go there for the reasons you outlined.
MF, I was talking to a bloke I worked with today and he was saying he bought one of these Gardenline self propelled mowers and he is very happy with it. I guess time will tell and I'm sure I will be the one to find out very quickly if he has any problems with it. I didn't ask what sort of warranty it came with
Why not just buy a used SP toro recycler for the same money,easy to repair and has a simple SP transmission and it will last much longer
It's just so feature packed and versatile. It lets you catch, mulch or side throw. It had a wide cut and looks good IMO. Sorely tempted to break my new mower purchase virginity with one.
Yes someguy no doubt a Toro is a better proposition long term, but it's still an unknown quantity without a warranty and not knowing how it has been treated or how many hours use it has had.
Not likely to have the specs this offers.
You would buy a Toro any day instead of a self propelled Honda, fantastic motor,but a junk gearbox. A Toro with a Honda motor would be the best combo
The only reason us lawn care pro's don't buy something like the unknown brands is no spare parts available when needed
What i have cut using the Toro in one year takes the domestic house owner 60 years
Yes, rusty carbs are a curse on chondas. I have had quite a few. Ethanol fuel does'nt help as the ethanol can absorb water promoting rust. The good news is that carbs off ebay are around $15.
They certainly are cheap, no idea how they do it, I bought 3 last week, $10.80 each delivered
How do you tell if it's suits your particular Chondah? Do you need to buy more than one to get them that cheap? I probably need two.
Are old skool B&S diaphragm and gasket kits cheap this way as well?
I bought 5 Briggs gasket/diaphragm sets for $4.49 including delivery.
https://www.aliexpress.com/item/5-S...on-495770-795083-5083H-5083K/32833657354
The honda carb I got from the same place for GX160 for $10.95 incl delivery.
MF from what I have come across all the Chonda carbs are pretty much the same, and you can buy just one for that price, as for the B&S I assume you mean the top of tank with primer type, I usually just buy new carbs for about $14 delivered
Much appreciated NK & sparkler. Good to know this route if my attempts at a clean go pear shaped/fail miserably eek
Guess what everyone, it's Aldi mower time again! laugh
I did a search on Aldi and found a thread here on Aldi lawnmowers before I started a new one...lol
I went to the local Aldi today to get some things and I noticed the lawnmower on the front page of their new catalogue sitting at the front of the shop.
I would post some pictures or a link but this could be considered as advertising, it's probably best for you guys to just check it out in the latest Aldi catalogue. It doesn't go on sale until Saturday 2nd March 2019.
I tell ya what it looks like the formula 1 of lawnmowers..lol
Built to perform, but not to last like almost everything is these days.
I don't know which mower/motor it uses but I do find most of those bigger Chondas are heavy to start, they take a big pull to get them rotating enough to fire, even the lawn beetles take a heafty pull to get them going. If only Honda had thought about it a little and put a primer on them they would have been so much easier to start.
That's another beauty of a good starting powertorque, it often takes only a very light pull to fire one up.
I remember when new, they would fire up at the lightest pull of the cord less than half way up!
I wonder, could a PT with long shaft be made to breath new life to an Aldi 21" model?
Hi, Thats the one my brother bought last year. It leaked oil into the air cleaner from the motor, eventually would not go as the filter got clogged. It was taken back for a full refund no questions asked. Aldi service completely uninterested in any sort of repair. I wonder what happens to mowers like that.
All the best
Jeff
Jeff, I'm guessing the motor had too much oil in it for it to be pumping it up the breather hose, I guess they just go in the dumpmaster.
MF, I sold one of those 400 Gardenlines to an older bloke last week but it is too heavy for him to pull start, so I am putting a PT together for him at the moment. As for fitting a long shaft PT to a Gardenline, firstly you have to find the long shaft motor, they are probably about 5% of the PT's I get, then you have to drill the base to take the PT and also put a step in the height adjuster to go around the outside of the headBetter off just keeping the wheels and dumping the rest, but then the wheels don't even fit a Victa because the axle diameter is 14.8mm
Received one of these with the motor hanging off the deck attached only by the self-propelling belt and the cables.
The deck had rusted away around the three mounting bolts and it was on its way to the tip. A thick mass of dried grass cuttings was under the deck and on top leaf litter and grunge, no wonder it had rusted.
The motor had good compression and I thought it worth a bit of time and effort. Getting the crankshaft boss off was a hassle. Disconnected the self-propel mechanism, rotated the motor 30 degrees and drilled new mounting holes into the deck, cleaned out the fuel system and now have a nicely running mower, quite powerful.
Anyone wanting the SP drive belt let me know, yours for the cost of postage.
One less mower off to landfill
Here's a photo of the rusted deck. It appeared the previous owners had never bothered cleaning under (or over) the deck after mowing.
Did a couple of thousand square metres with it today, great mower. I reckon the quality is better than what Aldi sells these days.
BTW it starts very easily, it does have an electric starter but didn't come with a battery so just gets a pull on the rope. There's no choke lever or throttle lever, all completely automatic, no fuel petcock either. Had some long grass to tackle and there was not a hint of stalling.
18,146 Registered Users
Members18,147
