0 members (), 8,822 guests, and 518 robots.
#87941 24/09/17 06:54 AM
Came across another Victa Lawnkeeper in very good physical condition but the engine only starts for a couple of seconds in full choke then cuts out.
Could anyone steer me into what this means? I presume some cleaning of the carby will be required.
Hi Mowerfreak, yep, common problem with any Chonda engine/carb.
Strip and clean the carby paying particular attention to the main jet, spray tube and idle circuit, remove and drain the fuel tank because there's probably water in it and it should be good to go.
Cheers, Ted
Thanks bigted. Could you describe this idle circuit? Good suggestion pulling off the fuel tank to eliminate possible h20 contamination.
When looking at the carby from the choke side, the idle circuit is the small orifice on the left. Spray carby cleaner through it and it should spray out cleanly form a small series of holes in the carby throat on the throttle butterfly side.
There are tons of videos on youtube that will give you step by step on how to do this thoroughly.
You are not wrong on all the videos. I'm pretty confident I'll have it running like new in no time now.
G2e, GFazz, LewisGS, mono1975, Ashes412
18,216 Registered Users
Posts106,871
Members18,216
