2 members (BobsYourUncle, DeanVR4), 4,996 guests, and 1,456 robots.
Page 3 of 4 1 2 3 4
Just had a ring around trying to source some suitable material (extra heavy 32nb pipe or 40mm x 30mm hollow bar) so that I could look at machining some sleeves.
I would need to sell many sets just to cover the material cost (offcut, minimum invoice amount) on the cheapest price I was quoted,just not viable for me.
I originally purchased a couple of 6202 bearings with 5/8" bores, they didn't fit(too small a bore to fit on the roller shaft).I would have measured the Anthony bearing with a vernier and considering od and width appeared imperial I wrongly assumed an imperial bore. Measured accurately with micrometers the od is more than 1.5 inches and the id is awful close to 16mm.
On another note when I rang Anthonys the price per bearing at the time was under $10 including gst (500 min), I would imagine they would be a slow moving item so the retail price seems reasonable .
Hi Gino,
Definitely not at $64.00 a bearing from one eBay seller, "Greenacres".
Hello BB
Has he ever sold one at that price ? grin
Gino
Just had a look, apparently they have sold three. I think I might buy some from ODK and chuck them on ebay .
Hi All,
Soon the online store will have a complete range of spare part for the model 45 both 17" & 20". We will be posting pictures in about 10 Days time of the complete machine that will be available. Once the machine arrives we will be able to confirm that they are the same. cheers2
Hi Bruce,
Firstly thanks for updating us with that info. It will be very interesting to see if the parts are all interchangeable.
I don't know what sort of idiot would pay $64 for a low tolerance bearing, but yes they are out there and I seem to not be able to find them. All I ever do is find the smart buggers that want to screw you down, but that's South Australia for ya !
Hi guys how have you been
I removed the outer metal cover on the rear roller bearings cleaned and repack with wheel bearing grease, here is a sneak peak of some of the work that has been going on at my house
Hope you fellas like it ?
HI CP,
I really like the colour in the last shot, it's amazing how colour temperature can change the colours in photography.
In actual fact if that photo is correct it's so close to original it's not funny. Did you by any chance get the formula for it or is it on a sticker on the can. Also how much paint did you have mixed up ?
Now for the bad bit,
Sadly I don't like being the bearer of bad news but it seems you've put the SB decal on upside down on the handlebar shield.
With heavy heart,
Hi Bb
Thanks for the bad news on the decal I have fix it thanks for pointing it out lol.
The photo is the actual colour and I am very happy with the way it turned out . Sorry but there is no paint code I can give it was just colour matched from behind the chain case .
Queensland paint supplies at Salisbury in qld mixed it up it started out as there green hammer tone of the shelf and one of the guys there tinted it to get it as close as possible 😃😃 [Linked Image]
Some more parts painted and the cork is just sitting there it is getting ready to be glued on to the right side of the gear so it is going on that one lol what is a good glue to use???
Thanks for your time
Hi CP,
Use "Contact" glue which is that yellow stuff that you put on both surfaces and allow to go off then bond together.
Hi Bb
Yep Contact cement thank you
Hi all how are you [Linked Image]
Is there a measurement for item #7 on how far it sits on the shaft or as long as it's sits over the woodruff key it's good to go
Hi CP,
Yes iten 7 (pawl carrier assembly) must sit perfectly central over the woodruff key and then you lock it down with the set screw #48
Hi all
Been busy here doing bits and pieces while the weather is no good here in Brisbane for painting.
Also found a brass height adjustment knob that I have been sanding and polishing to try make it shine [Linked Image]
And all so knock up another chain tensioner let me know if any one would be interested in purchasing one I will be selling them to fund my hobbies lol
Hi CP,
Those early series 1 Height adjusters look good polished up but they really need to be lacquered so as to stop the oxidisation that will naturally occur.
I noticed that the tensioner that you made for me had a thread tapped into it, did you do this deliberately or are you going to make future ones without so they just slide over the stub and are locked on by the 3/4 nut ?
Hi Bb
Yes I was thinking of clear coating the adjuster
The chain tensioner I made for you I just screw over my thread arm but will be tapping them out to run the same as the O/E tensioner
Hi all
Here's some pics it's been a while I have been busy with work and don't want to rush hope you like the progress [Linked Image]
Hi CP,
Love the progress.
One major point to make here, I note that you've just bought a Bed Knife straight from an online outlet and it is still a blank.
This must be ground along with your reel so as to match. You'd be surprised how out of whack that blade will be just being attached to the Sole Plate alone.
The sole plates are never perfect and as such the blade will follow the sole plate.
BTW I love the roller in Red opposed to being light Grey.
Hi Bb
Yes it is a new bed knife blade as my reel is at the end of its life but both have been ground to match each other.
Now where to start bolting it all up need help with the right steps to proceed with the build
Hi CP,
Basically you start with the sole plate first and then the rear roller ensuring that the slotted side bearing carrier is fitted on the RHS if looking from the rear, after that fit the land roll clutch drive in its two sections with the outer pressure plate last, this way you can fit the chain to drive the roller. There are specific rear roller fitting and alignment instructions in the following thread.
https://www.outdoorking-forum.com.au/forum/u...Rear_Drum_Assy_-_Bearing_.html#Post77975
From there you can loosely fit the reel bearing carriers and slide the reel in to place ready for final adjustment.
Assemble the transfer shaft and its bearing / carrier and attach it at the top of the side plate and also assemble the primary clutch assembly into its frame on the top engine deck. Loop up all the chains and slowly adjust it all up as it should be.
I guess from there onwards its all been covered on here again and again but if you get into any strife don't hesitate to holler !
Hi Bb
Thanks for the info I'll start getting it done
Hi again all
Just an update shot and also made the lock bolt for the clutch housing hope you like it
Hello Crumpet, BB, and all followers
Amazing documentation there.
I particularly love the first image (above). Brilliant!
Clearly, this post will be moved at some point.
I feel we have moved beyond introductions here.
Many thanks for this great restoration record.
Hi Jack,
I was going to suggest that to you to do. Can you move this to "Customising and Restoring" sub forum please ? as it gone well past the intros stage.
Hi CP,
That new chrome just looks divine doesn't it. I can never understand how some folk go for the cheap option of painting the handle bar assembly. I know that Chrome work isn't cheap any more due to all the EPA regulations and what plating shops have to conform with, but may I ask how much it set you back ?
Hi BB
Yes the chrome looks the part I think but a bit costly.
$250 from memory for the Handle bars the rear roller drive lever and the throttle control
Here is some more pics [Linked Image]
Just need a pull start rope and it's done better pics to come
Originally Posted by crumpet
Hi BB
Worth every penny. Stunning restoration. That green is gorgeous!! Is it hammered finish? Who mixed it for you?
Don't forget to wipe oil on that fresh chrome work.
Wow great job but have noticed restoration taking place on the laundry
I bet the misses would be loving that lol
Page 3 of 4 1 2 3 4
18,159 Registered Users
Topics12,760
Posts106,815
Members18,160
