1 members (Bruce),
11,314
1,439
Posts: 760 Likes: 4
Senior Contributor
Posts: 6,938 Likes: 322
Hi vint-mow
My understanding has always been to the top of the filler (on level ground).
I am unsure whether the specs referred to UK or USA pints. The VK30 took 1� pints. For UK conversion this would be about 700mls. For US conversion this would be about 600mls.
My best guess is that this US design took 600mls, and the AUS specification was expressed in North American pints.
Hope this helps. ---------------------- Jack
Posts: 988 Likes: 7
Hi Ian and Jack, The Villiers engine of the same design is fill to threads and do not overfill, if the measurement is 600ml I would go with that.
Posts: 760 Likes: 4
Senior Contributor
Thanks Paul and Jack, I will add a 1/4 pint or 600 mls and see what the level is. I'm guessing the oil will come to the bottom of the filler thread.
Posts: 760 Likes: 4
Senior Contributor
Jack, Are you sure it isn't 1 pint? The LV-30 manual says to add 1 pint. But I am not sure if the LV-30 differs from the VK-30, or if the abbreviation can be LVK-30 for that matter?
Posts: 988 Likes: 7
Hi Jack and Ian,
I thought 1pint was equal to 600ml?
Hi vint_mow and Paul I have both a Kirby VK30 spec and a Kirby VK30 Operator manual. Both say 1� pints. The issue is, as said, did Kirby mean UK or USA pints. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/06/full-7392-34954-pint_conversion.jpg) Perhaps Gadge could help here. In any case, 600ml would be a safe bet. Cheers--------------- Jack
Posts: 1,842 Likes: 14
Hi folks, My 1977 Gregory's #103 Victa workshop manual says approximately one pint, for the VK30.
That would be an Imperial Pint, not US! We didn't know much about US units of measurement here, in those days. 1.25 US Pints is pretty close to 1 Imperial Pint, as a US Pint is 16 US Fluid Ounces.
In practice, the correct fill level for these, is just short of overflow.
We used to use the technique of fill to that level, then rock the crank so as to 'suck down' the oil, then allow it to stand a short time, to establish the true level.
Cheers, Gadge
G'day GadgeMany thanks for the clarification on that. The discrepancy between your later Gregory's and the Kirby docs re oil capacity suggests that Kirby probably copied the USA documents, whereas Gregory's converted capacity to Imperial. I mean, 1 Imperial pint is = to 568mls; 1.25 US pints is = to 591mls I understand that 600 ml is a nice, even measure for both. For the record, I make available the specs, user and parts lists here:- https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/86685/KIRBY_-_VK30_Engines.html#Post86685Cheers---------------- Jack
Posts: 760 Likes: 4
Senior Contributor
Many thanks for the clarification Jack and Gadge. You have helped clear up a lot of the confusion.
Topics12,778
Posts106,882
Members18,238
