2 members (Dandare, MowingManiac), 3,313 guests, and 448 robots.
by Bumps - 19/03/26 11:57 AM
Mower wheel ID.
Shout Box
by geobee - 14/03/26 08:36 PM
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
by Bumps - 01/04/26 05:37 PM
Mower wheel ID.
Eaton Model 6/7
by Bruce - 20/03/26 09:50 AM
by Bruce - 19/03/26 11:52 AM
Shout Box
by Bruce - 16/03/26 08:10 AM
Early Morrison rotary mower
Rating: 5
Page 3 of 4 1 2 3 4
Hi Folks
With regards to leveling, I did mine and put a fair amount of sand into depressions etc. With all the wind and generally crappy weather we've had over the last few weeks, a couple of spots have depressed again. Am I able to continue to lightly build up the sand as the grass fills in or would that be considered stressing the lawn throughout its growing season?
Joe
Hi Joe,
Honestly there's no way that you'll stress Couch grass at all, only if you tip petrol on it will it suffer, so don't hesitate to put more sand over the top. I will say though it would be best to keep it damp until the grass comes through it and stabilises the surface.
Hi All
Just wanting some advice. I am young and have always loved seeing a nice lawn.
I laid my grass last December and doing my best to get it perfect. I have wintergreen couch and it seems to get thatchy very quick. I also have the the problem of the mower digging in on the side and leaving brown spots as the ground isn't flat enough. My front yard is on a incline what is the best way to go about fixing my issues?
At what stage did you start mowing with the cylinder mower again?
Hello Mr mr,
Who's your question directed at ?
Bonnar bloke
Sorry I tried to reply to a photo.
After cutting the lawn right down and putting sand down. At what stage do I start using the cylinder mower or do I cut with a bush mower until the sand has all disappeared?
The couch has covered about 85% of the sand at the moment.
Hi Mr mr,
It sounds like I'm responding to "Happy Gilmore".
Anyway you should be fine with your Cylinder cut if you've already got 85% coverage. I'd wet it down lightly half an hour before just to keep the sand down and not flying around due to the reel motion.
Hello guys
Fantastic topic and a great read a lot of great advice and tips learned for a newbie like my self.
Thanks,
Clarkey
Hi All,
There is some discussion of herbicides here, so thought I would post here.
I did a scarification of my couch lawn in early January (in Sydney). It has come back well in most areas, but is thin/bare in areas that are shaded by trees etc. I hope the Couch can come back in those areas come spring. Otherwise I appreciate any advice on giving it a helping hand.
My main issue at the moment is winter grass. I keep pulling it out by hand which takes a long time, and a few weeks later it looks the same. I have done some research and found two products, but happy to choose anything else. The first is Embargo which is mentioned here. This seems to be a pre-emergent and I may be too late to use that as the winter-grass is already quite actively growing. The other is Dimension EW. This is a pre and post emergent and seems to control a wider range of weeds. Perhaps this is a better choice given that I am late on the pre-emergent timing? Any advice appreciated.
Also, I use Kamba M to control broad leaf and creeping Oxalis with limited success. It seems to knock the weeds about, but they most often recover. Can anyone suggest something better for particularly the creeping Oxalis which is difficult to remove by hand. Most of the broad leaf is easily hand weeded, so I mainly want to get rid of the stuff that is not and creeping oxalis is a real problem for me.
Adrian
Hi Adrian,
Just a quick piece of advice regarding scarification. January is just way to late to do this. Generally one would apply this process late October (depending on the start of the season) into early November. January is really far too late and the lawn doesn't get the opportunity to recover enough in that short time frame.
Hi BB,
Yeah, I knew it was risky, and it has mostly come back well. There is an area that was not coming back under a tree. This was in the middle of February and we were still having long hot days. I trimmed the tree back and it is doing much better. Thin but mostly covered and not bare. I should have done that when I did the scarification and I think it would have been fine. There is a few areas in my lawn that just don't get great sun and they are suffering, so I have learnt from this process not to get too heavy handed with the lawn areas that grow slowly due to low light. Probably best just to scalp those areas and not do the full scarification and leave that for the fast growing parts of the lawn. I think it will all come back in time. I also have been battling army work the last 2 months which has not helped anything, but the 90% of the lawn is looking pretty good at the moment.... much better than it did when it was badly thatched.
I just need to get on top of the winter grass.... any advice on a product to use for that? Preferably something with both pre and post emergent properties.
Adrian
Tribute will kill annual grass in couch and will control kikiyu in most cases. Note word control. Winter is the best time to attack this problem,
Ended up getting Pronamide which is Propyzamide. $300 for 5L which should last forever. I was searching for suppliers of Winter grass herbicide in bulk and it is not that readily available, so had to go to a commercial supplier. They recommended this as pre/post emergent that should be used in Autumn and Winter and is cost effective. They had other very expensive alternatives. Will update how it goes.
Hi Adrian,
wow, you should decant it into smaller quantities, say 500ml and sell it off to recoup some of your costs as 5 litres will last you a lifetime and the next, unless you have a golf course to do of course.
I have a lot of winter grass!!
I wanted about 1L, but could not find anything. It seems winter grass herbicides are either really small from bunnings or are commercial size from a comercial supplier. I have some family/friends with Couch and similar issues, so it will come in handy. Hopefully it is effective!
So this Pronamide seems to work well. I have no more wintergrass. One area of my lawn was infested. You could barely make out the couch between the wintergrass. Now it is just Couch. That is not to say my lawn is weed free. I was out with the Dicamba on the weekend trying to get rid of broad leaf and oxalis. Hopefully I get that under control before they really take off in summer.
Is there anything I can do for my Couch in winter. It looks tired probably just because it is dormant. Is there anything recommended to get things rolling nicely into Spring? I still have some bare patches from the scarification. Hopefully in spring it takes off nicely and covers the bare patches, but I want to do whatever I can to get it moving as quick as possible as soon as possible.
Adrian
Hi vosadrian,
It's dormant and as such there's not much you can do. As they say in winter, "Don't Poke the Bear". It should've been fertilised in Autumn with a certain type of fertiliser which at this moment I can't remember its name, but I'll add it tomorrow. This should be done as a shutdown procedure prior to winter break.
all you can now do is wait until late October, depending upon when the season starts and then scalp it again and let the season do it's magic.
Update..............Fertiliser is Munns Emerald Green
Thanks BB.
I did fertilise in Autumn, but just used some Scotts with lawn grub insecticide, which may have been the wrong thing. Appreciate if there is something that is particularly good that I can use next time.
Adrian
A great read this thread was. I learnt a lot.
I have a question regarding lawn going to seed.
I try to mow twice a week, but once a week in a pinch. I have Windsor Green couch.
My problem is that the seed shoots just get laid flat against the lawn and look unsightly after the mow.
How do others tackle this?
Tony
Hi Tony,
This is simply happening due to bad reel to bed knife adjustment, in other words too much of a gap between the two components which is simply allowing the antenna heads to slide between the two and not be cut off.
I'm not sure what state your reel and bed knife are in, maybe you can enlighten us about it, but if it hasn't been done in quite some time then you'll need to get both sharpened and re-installed with the correct adjustment so that this doesn't happen again any time soon.
Page 3 of 4 1 2 3 4
Pazzaboy, mgman, Drennie, RobNich, JLAU
17,905 Registered Users
Topics13,076
Posts107,348
Members17,905
PHP: 8.3.30 Page Time: 0.069s Queries: 56 (0.056s) Memory: 0.7323 MB (Peak: 0.8472 MB) Data Comp: Zlib Server Time: 2026-04-03 07:35:54 UTC
