0 members (), 8,872 guests, and 366 robots.
G'day folks,
Some of these could apply to OPE too... grin
Here are some actual maintenance complaints/problems, generally known as squawks, submitted over the years by Pilots to maintenance engineers. After attending to the squawks, maintenance crews are required to log the details of the action taken to solve the pilots' squawks.
Problem - Left inside main tyre almost needs replacement. Solution - Almost replaced left inside main tyre.
Problem - Test flight OK, except autoland very rough. Solution - Autoland not installed on this aircraft.
Problem - No. 2 propeller seeping prop fluid. Solution - No. 2 propeller seepage normal. Nos. 1, 3 and 4 propellers lack normal seepage.
Problem - Something loose in cockpit. Solution - Something tightened in cockpit.
Problem - Dead bugs on windshield. Solution - Live bugs on backorder.
Problem - Autopilot in altitude-hold mode produces a 200-fpm descent. Solution - Cannot reproduce problem on ground.
Problem - Evidence of leak on right main landing gear. Solution - Evidence removed.
Problem - DME volume unbelievably loud. Solution - Volume set to more believable level.
Problem - Friction locks cause throttle levers to stick. Solution - That's what they are there for!
Problem - IFF inoperative. Solution - IFF always inoperative in OFF mode.
Problem - Suspected crack in windscreen. Solution - Suspect you're right.
Problem - Number 3 engine missing. Solution - Engine found on right wing after brief search.
Problem - Aircraft handles funny. Solution - Aircraft warned to "Straighten up, Fly Right, and Be Serious."
Problem - Target radar hums. Solution - Reprogrammed target radar with words.
Problem - Mouse in cockpit. Solution - Cat installed.
Defect: The autopilot doesn't. Action: IT DOES NOW.
Defect: Seat cushion in 13F smells rotten. Action: Fresh seat cushion on order.
Defect: Turn & slip indicator ball stuck in center during turns. Action: Congratulations. You just made your first coordinated turn!
Defect: Whining sound heard on engine shutdown. Action: Pilot removed from aircraft.
Defect: Pilot's clock inoperative. Action: Wound clock.
Defect: Autopilot tends to drop a wing when fuel imbalance reaches 500 pounds. Action: Flight manual limits maximum fuel imbalance to 300 pounds.
Defect: #2 ADF needle runs wild. Action: Caught and tamed #2 ADF needle.
Defect: Unfamiliar noise coming from #2 engine. Action: Engine run for four hours. Noise now familiar.
Defect: Noise coming from #2 engine. Sounds like little man with hammer. Action: Took hammer away from little man in #2 engine.
Defect: Whining noise coming from #2 engine compartment. Action: Returned hammer to little man in #2 engine.
Defect: Flight attendant cold at altitude. Action: Ground checks OK.
Defect: 3 roaches in cabin. Action: 1 roach killed, 1 wounded, 1 got away.
Defect: Weather radar went ape! Action: Opened radar, let out ape, cleaned up mess!
Gadge, my kind of humor, but does anybody read these reports?
Yes....
UNITED AIRWAYS TRAINING VIDEO:-
[video]
[/video]
Context here:-
[video]
[/video]
Moderated by  Bruce, Deejay
18,172 Registered Users
Posts106,820
Members18,173
