1 members (MarkusB), 7,208 guests, and 1,831 robots.
my victa mulchmaster self-propelled is up for a new donk, it has a briggs 850 on it - can someone tell me the shaft diameter & length I need?it's the MSP564 model
LRT Offline
Hi Redeye, In order to look up the replacement engine, I need the existing engine's Model, Type, & Code.
The numbers are etched/stamped into the plate above the exhaust.
See the red circle in the picture below:
A great opportunity to put a powertorque on it.
it's a 122Q42-0013-H1
lol, got sick of mixing 2 stroke many years ago
LRT Offline
This engine has not been superseded. You should be able to order a new Briggs & Stratton with the same model and type.
The crankshaft part number for that model and type is: 796924
It is worth checking the existing engine's shaft as Victa may have modified it from standard.
See the attached technical drawing below:
LRT Offline
Ps. what happened to the existing engine?
its been worked almost to death (l'm a contractor) and not worth my while rebuilding it - thanks for the info, much appreciated...and yes, l need to know if the self-propelled victa boss is 7/8" or 1" internally https://www.outdoorking-forum.com.au/lawn-mo...icta-pulley-engine-4-stroke-vsd-ee14475a
LRT Offline
It is most likely 1".
However, Victa may have altered the shaft from the standard 1" size.
Hopefully someone can confirm for you.
18,232 Registered Users
Topics12,777
Posts106,881
Members18,233
