2 members (looktall, JEH), 7,962 guests, and 2,567 robots.
#83193 27/02/17 09:57 PM
I just got a Powertorque running, no history on it, starts first pull revs and idles no problems but every now and then there is a clunking noise which is quite audible. Blade carrier and blades are tight, has to be something inside I think, I haven't pulled the motor off the frame to see if it is something like the wheel hitting the coil but it only happens on the odd occasion. Any thoughts?
NormK #83196 27/02/17 10:30 PM
When this has happened to me it's always the blade carrier/blades, usually the plastic washer is starting to deteriorate. Apart from that I'm not really sure, is the noise occurring at regular intervals or is it randomly occurring?
NormK #83207 28/02/17 05:19 AM
Hi Tiger, noise is random, can't think what it might be, it is a heavyish noise
NormK #83209 28/02/17 06:48 AM
hello Norm , I,d open it up as it probably needs gaskets , just check all, if it;s worthit decoke and clean rings, ex port.....
it's only time..
NormK #83215 28/02/17 07:32 AM
I had an otherwise good circa 1979 green Mustang that always made this 'koonk' 'koonk' 'koonk' sound when revving at the limit and under load.
I have the same thing with one of my power torques as well. My theory: the quality of fuel messes the detonation timing and is like a car pinging.
My yellow Vortex makes that sound at low revs and sounds fine when revving!
NormK #83216 28/02/17 07:58 AM
Mowerfreak, you could be on the money there, when I started this it smoked the shed out in a couple of seconds, (always a good idea, the spiders don't like it in the shed) it obviously had a lung full of oil in the crank, probably fuel left on, and drained into crank and petrol had evaporated out. Anyway I started it a little while ago and I didn't hear the noise so it may have been the problem, but it wasn't at high revs, just at high idle
NormK #83222 28/02/17 12:19 PM
Could be a foreign object residing under the flywheel, clunks when it works its way into the path of the moving flywheel.
NormK #83225 28/02/17 06:20 PM
Almost what it sounds like Bigted, if I get a chance I will pull the top off and see if there is anything in there
NormK #83229 28/02/17 11:28 PM
Noise seems to have gone now that the smoke has cleared, must have been excess oil in the crankcase
NormK #83231 01/03/17 06:23 AM
Goodo Norm; it's curious that excess oil could have that effect, though. confused
NormK #83232 01/03/17 09:31 AM
I always thought lacking oil was far more likely to cause unwanted noises in an engine.
NormK #83236 01/03/17 05:29 PM
I will run this a few more times to make sure the noise has gone and let you know, I know it doesn't make any sense, more curious than anything
NormK #83238 01/03/17 06:52 PM
You can always rebuild it or replace it with another one if it pops.
mono1975, Ashes412, icon1954, jimmywa, Cumborah Kid
18,213 Registered Users
Posts106,871
Members18,214
