10,139
1,423
Hi everyone. I'm completely new to the SB45 scene, and in fact the entire manicured lawn thing. The whole reason I came about these mowers is that I decided I was sick of a defunct, cross bred, and weed ridden lawn and wanted to try and make something of it. I'm in the process of researching how I can make my lawn stunning, and in the process got into reading about reel mowers. Now I had no intention of buying a reel mower quite possibly for some years once I get lawn to a level that justifies it's use, but scouring on eBay saw me come across an offer too good to refuse for a tinkerer like me. Picked up two SB45's from a guy around the corner. He suggested I pop onto these forums (so is quite likely a member too - Hi Mark if you are!). Both have running engines, the twin rail has been re-powered at some stage but the throttle cable is not working. The Solid Deck has a throttle, but no drive as the clutch system appears stuck together. Both have dinged up catchers, but one has had attempted repairs riveted to it. Hopefully I can get to work on restoring one by the time I have beautiful lawns that justify these pieces of Aussie history! I will put two posts below, one showing each in more detail for those that wish to analyse and give me some tips! (Bonnar_Bloke)  ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/02/full-11170-33197-both.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/02/full-11170-33198-both2.jpg)
Posts: 2,998 Likes: 16
Hi xaymaca,
Great to have another Model 45 Owner on board to keep up the rage !
Well, where do we start on these two ? I guess I'd start on the Twin Railer which has a bit of a peculiar appearance which isn't concurrent with the time line in Model 45's. I feel it has had a Handlebar shield and chain case change as they are black opposed to green. The black units were issued around the 1975 era while the chassis points towards 1973 as it sports the earlier dual brass ID plates. Without knowing the machines full history we can only assume that a previous tenant has made some cosmetic changes. The engine should be in better shape than the Kirby Lauson that's on the Solid Deck machine and as such you shouldn't have to do any mechanical work on the Briggs unit as the Kirby will probably require quite a bit of surgery due to the nature and age of the early power plant.
What I really need to know is what end result you are chasing and what sort effort you are willing to apply ?
Look forward to hearing back from you.
Cheers, BB.
Thanks for the quick response, BB. Interesting pickups there Results I'm chasing... Well that's a very open question, one that I don't think even I know yet. I've always been interested in a restoration project, and things with engines have always had an appeal (eg doing up a car or motorbike). Realistically, while I have two young ones a project of such a scale is highly unlikely, so I thought this might be worth a shot. I guess it depends on the condition of each when I dive deeper into the rabbit hole, but I'm willing to put work into both. I'm thinking it would be fun to do the older machine up to new specification and see if I can make my money back on it, and then keep the twin railer for myself as I don't realistically need such a 'nice' piece of history and it would potentially be better in the hands of a perfectionist (does that make sense?). Given the twin railer already has had a heart transplant, it's no longer that matching numbers style spruce up. I'm not going to need one for a few years I would imagine, so if I do up the Solid Deck first and see how I go and move on from there. What are your thoughts on what I should look out for on the Solid Deck ? Is there anything that stands out as incomplete or incorrect on that one ? Apart from the catcher being in bad shape.
Hi xaymaca,
Well your idea is good, now all you have to do is follow through with it and you will get your money back plus a bit more to fund the twin railer.
Now the first thing to do is to get the engine up and running to see if that is even a viable power plant or if it's a bin job. I'm sure you don't really want to be doing a full engine rebuild as that's only going to eat into the profit margin.
So there's the first thing to do from where I see it.
The engine is the most crucial part of the restoration process while the rest of it will not be that much of an issue. Honestly it's all about the Kirby.
Cheers, BB.
Well it's definitely a runner. While the choke doesn't seem to be connected to anything, it all appears present and starts in a pulls or two with some experimentation on throttle positions etc. I can't tell what it's like under load as the clutch mechanism isn't functioning (doesn't spring back out with the lever, the throw arm moves but the housing doesn't follow).
Following through will definitely be a big part of it. What are your thoughts on rechroming and powder coating, vs spray pack paints? Obviously the budget changes significantly, but the durability of powerdercoat would be better.
From the sound of things, the most inhibiting factor will be getting the reel and knife sharpened - Melbourne seems to be the unloved child for these machines from all the searches I've done. WA, SA and NSW being the high populations. I'm thinking I may have to send them off somewhere rather than hoping an engineer down here can 'have a crack'.
Hi,
What would be wrong with the choke as all it does is operate a butterfly right below the lever that you move through 90 degrees. Positions are as follows, off pointing to the right as view from behind the machine, 45 degrees half on and 90 degrees full on. (in line with the manifold)
If it doesn't smoke like a train and has good compression then you've got a good one. How much free play is there in the main butterfly shaft as this is where most of the Kirby's problems arise ? BTW yours probably looks worse than it really is due to it being left out in the weather and not having worked its backside off.
As far as Powder Coating is concerned, I'm definitely not a fan as its hygroscopic which means it sucks in moisture which in turn creates rust between the surface coating and the substrate metal. This issue doesn't really affect paint that much. Powder Coating is done purely as a more economic method in mass production and less trades people involved which equals less money paid to employees, thus more profit.
Good rust removal, proper primer and a good top coat wins every time.
Yes you are correct with the trends of cylinder mower ownership in Victoria, it's rather low compared to the other warmer states and that should give you a bit of a clue as to why more of them are in SA, WA, NSW and QLD. Melbourne was traditionally a much colder part of Australia in the 1960 and 70's when most of the 45's were being built, but of course it was like that way before the 45 was ever conceived.
I'm sure you'll find someone in Melbourne that does that type of work. Just go to your local bowling club etc. and ask where they get theirs done and I'm sure you'll get a great result.
Cheers, BB.
BTW. That fuel tank modification on the twin railer is a beauty. In the case of that machine it's been done due to the fact of a Briggs being fitted and the fuel tank not clearing the handlebar as that machine originally had a Kirby on it also and they had the tank sitting forward. It wasn't until SB crossed over to using the Briggs engine over the full range that they had to alter the lower handlebar section with a kink to clear the 1 Quart fuel tank.
...and that is why I thought it would be good to get your input! I didn't even realise that it was a modification, but looking at it now it has clearly been put on 'stilts'. Good pickup.
The Kirby doesn't seem to smoke, and compression is there when starting. Perhaps over the weekend I can try and capture a video of it.
RE: the choke, the linkage looks like is it supposed to have something connect to the end of it (spring or cable maybe?). That was the reason I wasn't sure, and it seems fairly loose. I'll try and have a play with the throttle butterfly and see if there is play in that too.
Spray pack paint sounds like a go, saves me having to take time off work to take it somewhere as well.
Is there an issue with sending the sole plate, knife and reel off for sharpening if I can't find anyone locally? I think a lot of the bowls clubs down here use synth turf these days for to the same reason there aren't that many SB's around!
Hi, I guess I've been around these things for many years now and that all adds up to experience which you just can't go down to Coles and buy at a "Down Down" price. Sorry Jack couldn't resist that line. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/02/full-5156-33215-full_11170_33203_carby.jpg) The choke is the long flat lever on the left side of the photo just under the Air Cleaner Barrel and the main butterfly is the next item back towards the engine that has a linkage connected to it and should go left across to the governor lever which should have a spring tensioner attached between it and the throttle linkage assembly where the cable attaches to the engine. You'll see a series of vertical holes in the governor lever and also on the accelerator mechanism for tension adjustment. Cheers, BB.
OK, so had a bit more of an investigate of both mowers tonight (wife out and kids asleep!) Started the Kirby and took a quick vid. This was from stone cold and no pulls yet. I'm finding that I couldn't get it to run with full choke or no choke, it had to be 45 degree angle or nothing. Kirby motor starting and running - HERE I took the chain cover off and unfortunately, one of the chains was missing ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/02/full-11170-33216-00000img_00000_burst20170227194806_cover.jpg) But wait, what's that hiding in the chain cover? ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/02/full-11170-33217-img_20170227_194929.jpg) Pictures of the gears ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/02/full-11170-33218-img_20170227_194731.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/02/full-11170-33219-00000img_00000_burst20170227194723_cover.jpg) Also took some pics of the other gearset on the twin rail. I did some initial investigating and I'm *thinking* I may be lucky with the rails, not counting my chickens yet though. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/02/full-11170-33220-img_20170227_202214.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/02/full-11170-33221-img_20170227_202201.jpg) And in regards to the black handle plate, perhaps this will help you figure out what happened. I definitely know!The handles are also quite... aluminiumy! ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/02/full-11170-33222-img_20170227_193014.jpg)
Oh, and I forgot to mention. I got the throttle cable working on the twin rail - there was a return spring disconnected.
The clutch mechanism on the single rail is now doing the correct action too, I had to adjust that bolt under the throw arm and now works well. I had to look at the working one to see how it worked, I cheated. I also cracked open the clutch assembly, based on a quick look I would say that there isn't any cork in there. Need to pull it apart completely to assess.
Topics12,778
Posts106,882
Members18,241
