6 members (Chase91, MowingManiac, AMP, Willy Supercut, Peter9231, 1 invisible),
3,205
912
I suggest lubricating the upper and lower bushes in the starter motor with a good anti seize compound and checking the brushes while it is apart
Posts: 5,403 Likes: 35
dear bruce, I found out that the starter motor was not turning fast enough ,it was bulking !even through I had it fixed.so my friend has taken it off for a good clean up,hope. fred. Are you sure the battery is ok because it might be failing under load i.e. the battery voltage drops from 12+ volts to about 4 or 5 volts. Please check before going to much further.
dear bruce, I found that the starter motor cog wheel was upside down,and the inside of the motor was full of bush/dust,and it looked like the bush,s was not filed right,.fred
Fred, Just give it a good clean out and make sure that you oil up the bushes. Let us know how you get on.
dear bruce. I got back the s/motor,still not starting,I,ll get the battery checked. fred.
Topics13,066
Posts107,278
Members17,857
