2 members (niggz, Andrewb92), 5,730 guests, and 335 robots.
just a thought...
To me it looks like an ignitor system. If so then the ignitor if connected backwards the system will still spark; just out of time as would triggering on the wrong pulse from the flywheel.
Here old points systems used positive ground and the newer versions use negative ground. The polarity of the flywheel magnets determined which way ignitor has to setup.
Ok- so what do I do to reverse it? change the leads around to the opposite side?
Thanks for your help here
The wire from the module goes to the far side terminal on the coil
The other thing to try, is pulling the earthing pin out of the carby, to disconnect the cutout switch.
These crude switches are notably trouble-prone, so it's best to eliminate that as a cause.
"These crude switches are notably trouble-prone," Gadge would that not be the understatement of the year, I would be more likely to call it an abomination
ok thanks all
I will try these suggestions tonight when i get home and let you know how it goes
LRT Offline
Originally Posted by NormK
LRT went through this last week, he bought 3 coils and none seemed to work. He brought them over and I was able to show him that they all worked fine. Take the coil off and clean where it mounts, but the fact it has spark means I'm doubtful this is the problem
Hi Crowster36,
As Norm has said, I have spent countless hours trying to get a strong enough spark to jump the spark plug gap.
For your interest, here is the link to the thread detailing the diagnosis that may be helpful:
Identify Victa Pro 550
17,605 Registered Users
Posts106,900
Members17,606
PHP: 8.3.25 Page Time: 0.042s Queries: 31 (0.034s) Memory: 0.6598 MB (Peak: 0.7042 MB) Data Comp: Zlib Server Time: 2025-09-29 20:33:41 UTC
