3 members (georgemaver2002, Bruce, noileg), 4,632 guests, and 1,364 robots.
hey guys,
I have a steel VICTA base.. a couple actually and Im wanting to to tidy it. underneath, the bases have become pretty rusty and Im wanting to remove it so I can put down a coat of paint for a little extra protection. im not after anything flash, its not a fancy restore, just wanting to make it look better and reduce the progression of rust. I also want to do it on the cheap too if that's possible?
It would be nice to sandblast.. but, no sandblaster. I could always use that rust-eater chemical but not familiar with them.
I have used a wire wheel on a drill before, but that always seems to leave a fine layer of rust. Is it possible if I did that, can I use a primer with some sort of rust killer to just primer and paint of the top of it ?
Alternatively there's always electrolysis, but, I dont have a big enough tank for the base.. or a current working power source.
What do you guys use, any suggestions?
The other base I have is made of Aluminium and seems to have surface corrosion. It's a pretty solid base with no serious damage.. I'de like to restore it... though have never prepped or painted aluminium.. suggestions on how to restore (clean / prep / prime / paint etc..)?
Thanks in advance smile
Widget, the Victa bases are notorious for rust, and the Chinese ones are twice as bad, the left hand corner where the handle bolts on is the main problem spot. If you are just after rust protection, I rub the underside back as best I can and then give it a coat of fish oil. Once dry it is probably about the best rust protection you can get. If you want you can give it a couple of coats but it does take quite a while to dry
hey Norm, right about the bases, ive had a couple of vocta bases all rust in the same corner. here's the one im replacing
[Linked Image from i998.photobucket.com]
Thinking of transferring the engine to this VICTA tornbado base
though wanting to fix the underside if it's worth it.. rust seemed to have had a feast under there..
also the wheel on the tornado are seized.. I think there's a bit of rust build of at the inner side of the wheel axel(?) wherfe the inner bearing/bushing slides onto, which prevents it from spinning. tried using grinder on it.. not experienced and I think Im making flat spots..
Widget, it is a built in Victa self destruct method so that people have to replace their mower. The Powertorque motors are strong and will well outlast the bases. I just fish oil them, at least a lot better protection than Victa gave them. Just check the Tornado base, I think it might be deeper. I have a Victa base here that appears much deeper, but I haven't really looked at that one, it is sitting there for ron, lateron when I have nothing else to do. laugh
i line my wheelbarrow with plastic and use it for an electrolysis tank'
That's a great idea Gizmo! Plenty big enough for a mower base.
This
look at the gunk that came off this rotomo base
Thanks for the tip... though I don't have a wheelburrow lol frown.. I am however, looking into getting a plastic 44gallon drum. I have a metal one here and the base seems to just fit in.
wow, that base looks nice.. is that after electrolysis or was there further prep work done ?
Hi Gizmo,
Could you please be so kind as to write up a step by step process in exactly how you are doing this so that other members could follow the same procedure and get these type of results ?
Nice result, very pitted tho. Did you use white vinegar and how long did it soak for? I notice vinegar is quite cheap in large bottles at the supermarket. Will you bother to fill in the pits with bog or spot putty?
widget another way to clean inside your mower base use your angle grinder fitted with flat knot wire wheel
flat knot wire wheels comme in sizes to fit most angle grinders serch ebay for angle grinder wire wheel
these wire wheels not like ones used on drills they really remove rust quickly .
must wear leatherr gloves and safty glasses when using them. cheers2
Hello again all.
i used electrolysis to remove all that rust.
i have an old pc power supply and use the 5 volts at 16 amps output. using a sacrificial anode. (my bbq plate).immersed in a solution of water and baking soda then added the bbq plate above the mower base. left for about six hours.
i just removed it from the bath and hosed it off whilst lightly removing gunk with a wire brush.did nothing else. and it was real real bad to begin with.
look up electrolysis rust removal.
I've used Electrolysis in the past and just started using it again. I'm using similar equipment, an old PC power supply running on 12v @ 10amp .. though am thinking of wiring up the 5v @ 30amp wires to see if it gets any better.
unfortunately my sacrificial anode seemed to have dissolved away lol .. quite surprised when I pulled it out.. seemed like acid attacked it.
as you can see.. the missing section isnt suppose to be missing :P .. might have to get myself something a little more solid.
One other thing I noticed, the last piece I cleaned up with electrolysis, I hosed off and left to dry, only to come back to find surface rust.. any ideas how to prevent that from happening ?
Picked up some SODA ASH from Bunnings today, active ingredient being SODIUM CARBONATE, the same stuff the americans use (ARM & HAMMER).. cost a couple $ more compared to Bi-Carb SODA, will see how it goes.
G'day Widget apparently it's used as an electrolyte so shouldn't make any real difference. I have used bi carb and believe it's pretty much all the same. Even the quantity doesn't seem too critical. I read you could use plain salt but it's a little counter productive. Just remember to only ever put steel in there. Again I have read that if you use galvanised it releases the zinc and stainless releases chromium both of which are heavy metals and not very friendly whereas using plain steel releases bugger all and can be tipped out without leaving nasties. As coper is not ideal in there I used concreters tie wire as I find rolls lying around on construction sites so can use it once or twice and then replace it. Apparently the smart battery chargers don't work because they sense the load where as an old battery charger or power supply works fine. They say that too high a power and it will pit the surface more and you could even use a spare car battery then recharge when done.
This
Hey Slash, thanks for the feedback info smile
Yeh I've always used Bi-Carb, seemed to work ok. Came across the SODA ASH, figured I'd give it a shot. I also use VINEGAR on smaller items such as bolts.. works rather well.. I should post a pic.. though I think the parts need to go into some water/Bi-Carb mix to nutrilise the acid otherwise it flash-rusts the parts smirk.. soemthing i've noticed on all parts, even the electrolysis parts.
I did hear somewhere that Sea-salt (i.e. ocean water) was a good conductor.. too bad no ocean near me.. would gone down with a bucket, give it a test :p
I wonder what the wire I used was made of... one thing I noticed was the water turned black.. unusual compared to previous electrolysis attempts... even the part I used for cleaning (mower blade plate) came out with black all over it.. even after hitting it with the hose. (might take a pic and upload).
I'll have to hunt around, try and find some normal steel.. couldnt find any before, so I used the wire mesh thing.
What about old car rotors ? think they're made of steel ?? maybe ill give that a shot...
Started off with the battery charger.. worked.. but not well.. it was low amps and waas more of a trickle charge so It'll send out these little pulses lol.. ended up modding an old computer PSU and using the 12v10amp.. though am planning on connecting the 5v30amp and maybe using something to limit the current flow down to 15-20amp if 30amp is a bit high.
Any opinions about using an old steel 44 gallon drum and having the piece(s) hang in the middle then using the drum itself as the anode ?
Too bad you are so far away, I have a couple of really nice Victa high arch alloy bases that are in near perfect condition, solve those rust problems for you.
Trev, Brilliant base those high arch alloy ones, just a pity Victa hadn't come up with the standard catcher they have used ever since
gml Offline
Greenfield Enthusiast
g'day,a guy at my work uses molasses bath's to remove rust and it does a great job.has anyone used this method?
G'day Widget, I've thought about using an old 44 as well because it would give an even current flow to cover the job being cleaned but remember how the sacrificial anode dissolves? You'll come out to find half your drum gone and your treasures on the ground.
When using electrolysis it apparently releases the hydrogen from the water which causes hydrogen embrittlement in the metal. This is a mayor problem in things that take load like gears and shafts. Apparently there are two ways to dissipate this hydrogen. The first is to leave it alone and it will come out over time and the other is to bake it in the oven. Please note I say apparently a lot as I've only done this a couple of times and my knowledge comes mostly from doctor google.
I have never tried the vinegar trick but have read of it a few times. Does that elcheapo vinegar do the trick?
From my understanding molasses is sensational and can be used mixed down with water but has three shortfalls. One is it takes longer. Two is the cost of molasses, even from a stock feeder and thirdly while molasses does dissolve rust first it will also dissolve good metal whereas electrolysis will only dissolve rust and then stop no matter how long your piece is left in the bath.
This
Thanks for the info Slash smile
With vinegar, just the cheap homebrand stuff is all I use. Threw smaller stuff (nuts n bolts etc..) into a jam jar, filled with Vinegar and left it on the shelf. All the rust and crap shows up on the surface smile.
Yep. It is slow [days to weeks, depending on thickness of rust], so you have to be patient. It will corrode sheetmetal parts if left in too long, too. And it does get pretty stinky.
It really has to be mixed with water. Anywhere from about 1+7 to 1+10 molasses:water ratio will work well.
Tip: Use hot tap water when mixing it up - speeds things up. A 5kg bucket of black molasses was about $13 from the local stock supplies joint, last time I bought some.
Soda Ash is also available in bigger packs from swimming pool chemical suppliers, and that works out cheaper than bicarb soda [aka Sodium Hydrogen Carbonate]. I would not use any chloride-containing electrolyte solution, like salt water - the metal absorbs some of it, and perpetual after-rust problems are likely.
For mechanical rust removal, a 'twist knot cup type' wire brush on a 4" angle grinder is about the best method I've used. As freebird mentions, good PPE is essential - eye protection [preferably full face shield], long welders' gloves and a leather apron. The flung off bristles will penetrate normal clothing.
Rapid after-rusting is a problem with any of the chemical [including electrolytic] de-rusting methods.
One of the best ways to passivate the surface is to rinse it off thoroughly, and swab it with diluted Phosphoric Acid solution before it dries. This will form a thin protective grey coloured Iron Phosphate surface coating, which is also a good base for the primer coat. Nearly all of the commercial 'rust remover' products are Phosphoric Acid based - if it doesn't show on the label, the MSDS will say. Try a dilution of about 1+4 to start with; if the metal surface doesn't turn grey pretty quickly, add a bit more rust remover.
For small steel parts, just boil them for 5 minutes or so in clean water to passivate them.
Thanks gadge :), just wondering, do you prefer getting straight Phosphoric acid and diluting if needed or do you recommend just getting a specific ready-to-use rust remover/converter?
Also, picked up a set of those twist knot angle grinder attachments, seemed to work quite well.. even on my finger :p .. took off a heap of rust from the blade plate.. primed it up, gonna give it a quick coat of black and chuck it back on the mower..
If you can get your hands on Concentrated [85%] Orthophosphoric Acid, dilute it at 1+9 ratio. That works for me. As always, add the acid to the water, not vice versa!
The rust removers are easier to get for most folk, hence my recommendation. The commercial rust removers also usually incorporate some sort of surfactant, to act as a degreaser for metal that isn't squeaky clean.
Yup, they're pretty aggressive at removing rust. Only thing is, they won't clean all of the residual rust out of pits in the surface, unless the pits are shallow. My procedure there is, to give the pitted areas the Phosphoric Acid treatment before painting. If appearance matters [as in the upper side of a mower deck], metal-filled epoxy such as Devcon or JB Weld can be used to fill the pits, after they've had the acid treatment.
Great! thanks Gadge, much appreciated smile
Quick question.. with Phosphoric acid, when it reacts with rust it creates a primed surface .. though with rust being scattered after cleaning, would you still apply a layer of epoxy to cover the areas that weren't primed by the PA ? (if u know what i mean)
Well, the phosphoric acid actually dissolves the rust, and it washes away with the rinse water - if it has been in contact long enough. That's why the commercial rust removers have a 'thickener' added, to give the acid time to do its job.
Scratching as much of the rust as you can out of the pits before applying the acid also helps, but it's a tedious job if there are a lot of them.
Those epoxy products are quite viscous, and very suitable for filling pits, but not as an overall coating. It's simpler just to swab the whole surface with the acid after doing the pitted areas - as soon as it turns grey, it's ready to rinse off, dry, and hit with a primer coat.
...layer of epoxy to cover the areas that weren't primed by the PA ? (if u know what i mean)
woops I think I meant to write primer .. not sure why I put epoxy.. maybe meant etch primer *shrug*
Thanks gadge :), where do you recommend getting the more concentrated Phosphoric Acid / Orthophosphoric Acid? I found this site which has a local store if its still there) http://kegking.com.au/cleaners-and-sanitising-equipment/pure-phosphoric-acid-96-pure-300ml.html .. not sure if it's thick like the one you mentioned though.
thanks for the info smile .. I think I meant to write etch/primer though lol crazy
Thanks again smile cheers2
Well, that's cheap enough, but it's blindingly obvious that that mob have no clues about calculating acid concentrations.
Commercial 'syrupy' Orthophosphoric Acid is 85% H3PO4, and diluting that with 4% demin water sure doesn't get you to 96%!
Their packaging looks a bit suss for that product too, unless it has a back label with the hazard diamonds for Dangerous Goods Class 8, and other safety info on it.
The 'thickened acid' rust removers are sold at paint and hardware shops, as either 'rust removers' or 'rust converters'.
The other commercial 'rust converter' chemistry in use is Tannic Acid based, but this type is less common than phosphoric acid, and much more expensive these days.
I'll have to check out a some more hardware stores.. bunnings and SCA have the converters, but I think the % is only <50% Phosphoric Acid.
There's also sydney hardware.. but that's some distance from me.. they seem to have some.. various cleaning suppliers too around me ill have to call up.
Here a clip of my Electrolysis setup, anyone have any suggestions on it, feel free to post smile
[video]
[/video]
PSU running @ 12v10A .. oddly enough, i tried 5V30A but it didnt seem effective.. almost as if nothing was happening *shrug*
18,183 Registered Users
Topics12,763
Posts106,823
Members18,184
