1 members (Bruce), 4,699 guests, and 1,921 robots.
Hi all I need to lay new turf in my back yard would it be a good time to lay now ?
Would you recommend removing old turf or round up old yard then lay on top
Or turn the old yard mix with new soil as I do have reshape my yard as well I will be putting couch grass in
Thank you
Will up load photos later
Hi Golf and Bundy it is good time for laying turf in Brisbane now our temps aren't far off normal spring temps and you should get a good chance to let the turf establish before we get the warmer weather that can sometimes stress turf.
I'd recommend the following:
- Mow old lawn low
- spray out lawn with round up,
- wait 2 days and irrigate. Irrigate a few more times in the following week to promote weed seeds to germinate.
- wait for 7-14 days for weed seed and spray again
- hire a pedestrian cultivator and cultivate lawn to 100-150mm
- depending on soil type if you want a more level and free draining surface now is the time to incorporate washed river sand (USGA sand) and any other amendments. To work this out do the following
- pH test your soil with a kit from bunnings or get a soil test to see what to incorporate. You want to be around ph 6-7 for most warm season turf. If it is too acid (low ph) which applies to most Australian soils the solution is to add agricultural lime or dolomite. You can also use poultry manure. If it is alkaline and has a high pH you can increase the acidity of your soil by adding things like compost and manures, leaf litter and mulch. Iron chelates works too. In extreme situations, you can use acidifying fertilisers (like ammonium sulfate) - one handful per square metre, once a year. Sulphur works very slowly and you won't notice a change in your pH for about 6 months.
Id recommend 25kg rooster booster or dynamic lifter/100m2 and pure river sand it will get your lawn hopping.
- order the sand and have the amendment ready so that they are at your place on the same weekend that you hire your cultivator.
- to calculate how much sand to order work out where you want your levels for example:
you may have a 10cm drop off paths and want to make your 100m2 lawn level with all of these do the following calculation.
a = Desired height increase - Height of turf (Normally 30-50mm)x Area
b = 30% Sand for compaction and re-levelling
c = a+b (Sand volume to order)
a = 100mm - 30mm * 100 = 70mm (convert to m for m3 values) 70mm = .07m * 100 = 7m3
b = 7m3 x 0.3(30%) = 2.1m3
c = 9.1m3
- Add half the sand and dynamic lifer then cultivate and mix in with your existing site soil.
- Rake to a rough level
- Add second half of sand and dynamic lifter and cultivate and mix in with your existing mix.
- Keep the extra third of the mix aside for final levelling
- Roll and screed to your desired heights using a heavy roller and level lawn or a large wooden screed.
- Irrigate it to complete saturation this will cause the sand to sink and bed in.
- wait for it to dry and add final amount of sand, screed and level and lightly rake for a fluffly appearance on the sand surface.
- Don't worry if you have sand left over save it for later for topdressing in seam lines etc.
- Lay turf: I'd recommend any of the following Green Couches: Santa Ana, Agridark, Tifsport, Grand Prix, OzTuff or Qld Blue couch (not a green couch) if you don't want the invasiveness for your garden beds. You could always wait a few years for TifGrand and TifTuf although I can't see them getting released commercially for 3-4 years.
N.B. with any soil addition make sure you cultivate them and mix them as not to get a perched layer and any unusual problems that come with soil layering.
Live the turfies dream and reap the rewards of getting your base right.
Wow thank you so much for this advice wally 89 I will start the process
Hello Wally and G&B
That response from Wally89 is amazingly comprehensive.
I have renamed the topic to reflect the wider subject matter.
I hope that's okay.
I feel this new forum will prove quite invaluable to members and guests.
It may also encourage collectors to contemplate the 'bigger picture',
or the purpose of the lawnmower - aesthetic improvement of grassland -
to turn grass into lawn.
Brilliant! Thank you.
Absolutely jack I am new to this lawn care so I find this site perfect and I thank wally for his infomation
Hi wally
what do you think of green leaf park couch as this is the stuff I got for the front yard I am so thankful for your advice
Hey Golf and Bundy,
Greenlees Park is an oldie but a goodie (its like wintergreen if its true to type). You can definitely fine it up with use of primo or other Plant Growth Regulators and regular grooming (I need to make myself a grooming scottie). I don't know if you follow Aussie Rules but the surface at Metricon Stadium on the Gold Coast (where the suns play) is Greenlees Park and its always schmick (they oversow with rye in late april). Which turf farm did you get greenlees from and how much did it set you back $/m2 if you don't mind me asking? You have any pics too?
Hi wally
I got my turf from Roberts turf on the Sunshine Coast I got it at a good price because of my cousin is good mates with the owner .. Have you seen sim rice on this page he has made a groomer for his scotty and I have spoken to him in regards to getting one made for myself just waiting for him to get back to me .i just restored a Scott Bonnar myself and have one reddy for a groomer set so I do not have to keep changing blades. I am going to make a airrator out of a old compressor tank and weld some spikes on it and be able to fill with water
18,186 Registered Users
Posts106,827
Members18,187
