1 members (Red Rum),
4,694
1,046
Hi all, My Scott Bonnar 45 is losing its drive when the reel is engaged. It is cutting fine but I have to push it to get going. I have tightened the clutch and drum chains and the cutter chain in the chain housing so that there is about 6 mm of play as best I can tell. I have also tightened the threaded adjuster for the clutch lever which has firmed up the play in it but none of this has made any difference. Any suggestions?
Posts: 2,998 Likes: 16
Hi Tim62A,
Have you had a closer look at how much cork is still left in the landroll clutch ?
Cheers, BB
Hi Tim62A,
Can you please supply some close up photos of the edge of the landroll clutch showing the cork thickness and also the clutch fork / cable area.
Cheers, BB
Hi BB, I finally got to check out the clutch cork but it looked fine in terms of thickness, but glassy/smooth and bit greasy. I gave it a bit of a roughen up with some sandpaper and readjusted the clutch setting and it is working a lot better
Members18,156
