0 members (), 1,468 guests, and 1,142 robots.
GMC 750W Generator
Suring problems
Viking MT 423
by Bumps - 30/05/26 12:23 PM
GMC 750W Generator
Suring problems
Viking MT 423
by Bruce - 15/06/26 08:59 PM
Deutscher 360
by Bruce - 07/06/26 10:21 AM
by NormK - 04/06/26 02:09 PM
by maxwestern - 03/06/26 05:27 PM
by monala - 29/05/26 12:24 PM
#73069 28/02/16 10:32 PM
Going to need a bit (maybe a lot) of penetrene on this one, I had to cut the chain off with a grinder so I could move it, obviously been sitting outside for many years, at least the motor turns over and the oil looks clean
NormK #73516 10/03/16 09:29 PM
Ok so this one is moving along slowly but I have a question about how the deck pulley is attached. I seem to remember with the last one I did that the pulley was screwed on, does this sound about right?
NormK #73523 11/03/16 06:47 AM
prd Offline
MOD & GREENFIELD TECHNICIAN
G'day Norm,
You might be right there. I've not had a deck apart but will need to soon as the bearings are getting v noisy on the daily drive. I'll be very interested in what you find. I think I recall that the tractors are a LH thread - but of course that beastie chutes to the right and so is probably opposite?
Superdooper might know. Super, you out there?
NormK #73525 11/03/16 06:56 AM
prd Offline
Ok, just had a look at the IPC for the tractor. It shows no woodruff key or the like and the pulley is described as 'Pulley LH' which suggest it is indeed threaded and a LH thread on the left-shooting machines - yours being opposite, me thinks
That's going to be a bugger to remove
NormK #73526 11/03/16 07:21 AM
Thanks for that, I got it off without too much trouble, I had a feeling from memory that it was screwed and it is and was pretty tight,had to use a cold chisel on it to get it moving and once free it was easy to spin off and put the new bearings in. From memory the bearings in the Stallion were bigger, may not have been but I remember with that one I machined the housing out because the bearing was a bit loose and I then fitted 3 bearings in it to give it a bit more strength. I rebuilt an Anniversary model last year but I didn't have to replace the deck bearings because they had just been done. Thanks for the heads up on those being LH threads, I will note that
NormK #73531 11/03/16 08:34 AM
Yep, the HD8 and the 5XL are both right side throw models, so would use conventional RH threads on the cutter pulley.
IIRC those were the only RH throw Greenfield ride-on models. The IPL's for most of the later LH throw models don't mention the LH thread though...
Gadge #73537 11/03/16 04:48 PM
I'm having a little problem with understanding how they were able to make blades spin in the opposite direction to make them a left throw, what am I not understanding here?
NormK #73561 12/03/16 05:54 AM
Take a look at a blade from the top. The right hand side has a cutting edge and the left side has a bend up to create suction. In an opposite rotation the right side has the bend and the left has the cutting edge. My Simplicity is the same.
This
NormK #73562 12/03/16 06:13 AM
Thanks Slash, but how do they reverse the rotation of the blade carrier?
NormK #73566 12/03/16 09:48 AM
The simplicity runs through a bevel gearbox and a pulley system. I don't know anything about g\
Greenfields. Do they run a twist in the belt?
This
NormK #73568 12/03/16 12:14 PM
Poo Slash I just dawned on me this very minute while I was thinking abut what you were saying about the twist. So [Censored] simple I feel stupid for asking, the left throw ones have a forward mounted motor, the right throw have a rear mounted motor. simple, simple ,simple
NormK #73569 12/03/16 05:41 PM
prd Offline
The front or rear mounted engine bit is not what gives the opposite throw. Either way it will throw to the right if 'directly' driven.
The left throw machines have a front mounted engine and the cutter belt runs aft, does a 180 degree turn behind the deck (this is the tensioner) and then on to the deck. I'm talking tractor models. Without the 180 degree turn they would also shoot right
Your stallion, rear engine of course, but the cutter belt must also run direct to deck without doing a 180 (?) and so had a different clutch/tensioner arrangement - and opposite throw
The HD8's had a horizontal shaft engine with the PTO pointing forward and a 'direct' line to the deck. The belts ran under the engine
Many ways to skin a cat smile
NormK #73570 12/03/16 06:14 PM
Yup. That'll do it too.
This
NormK #73574 12/03/16 07:31 PM
I went back to bed and thought about it and realized the motor position wouldn't make any difference. Looks like I'll have to get an anniversary model so I can get an idea how it works
NormK #73577 12/03/16 09:21 PM
Norm, what you have to look at is the idler pulley setups on the various cutter belts.
On the 5XL, the cutter belt will be nearly a straight run from the engine pulley to the cutter pulley. So the shafts run in the same direction.
The HD8 runs the cutter belt path through a 90� turn, around two idler pulleys, as the cutter spindle is perpendicular to the engine PTO shaft. The shafts run in the same direction, as with the 5XL.
The Tractor-X and later models have vertical shaft engines, so the cutter and engine PTO shafts are in the same plane.
But running a short direct belt drive wouldn't work at all well, for a few reasons.
So what Greenfield did, is to run the cutter belt path through a 180� turn, via two idler pulleys near the rear of the cutter deck.
This allows the cutter pulley to be moved vertically [as cutter deck height is adjusted] without severe misalignment between the belt and either pulley - which would cause excessive belt wear.
However, the 180� turn also 'reverses' the direction of belt travel at the cutter pulley, and hence the direction of cutter rotation. So Greenfield had to go to LH throw decks on these.
It's not that easy to visualise, so here's a diagram:
As depicted here, the engine pulley rotation is clockwise.
NormK #73579 12/03/16 09:32 PM
Thanks Gadge, I didn't get involved with the deck, pulley setup on the Anniversary one I had last year, this had all been replaced by the previous owner just before he gave up on it. The diagram is good and this will now allow me to sleep at night. I wonder how many sleepless nights old Mr Greenfield had staring at the ceiling trying to work out how to make it work. Same with the drive clutch wheels, always grabs my attention when I see the 2 wheels side by side on a single shaft with them turning in opposite directions. Thanks again that cleared that up
NormK #73587 13/03/16 01:46 AM
G'day Norm,
That design may not have caused Theo Reinhold [Greenfield's founder] too much lost sleep - I suspect he was one of those [now rare] folk who have an intuitive understanding of mechanical design principles. Used to be common, in the days when engineers had a lot of hands-on training.
Look at how little the basic Greenfield ride-on design has changed from the HD8...
The mark of a 'done right first time' design, IMHO. cool
NormK #73590 13/03/16 04:13 AM
Gadge there were all designed without the aid of computers, Australia had some brilliant design engineers in that era. You just to have to think about the designs developed here and then sold overseas. The list is amazing. The Greenfields are such a tough, basic machine designed to do exactly, cut grass.
NormK #73612 13/03/16 01:12 PM
This thing has some odd designed deck height adjuster that uses the deck wheels as the height adjustment at the rear. This then has the wheels in full contact with the ground and then when turning these wheels are forced sideways as in a bogey wheel setup. I'm not sure if this was the original design as the rear of the deck has been re-constructed (possibly because of the deck wheels being dragged across the ground ?). I'm going to see if I can do away with this idea and set it up so that the height adjuster lifts the whole deck up nice and square without the wheels being part of the adjusting system. Anybody have any thoughts?
NormK #73618 13/03/16 05:48 PM
prd Offline
G'day Norm,
That does look odd. When I first read your query above I instantly thought your problem was due to the excess weight of that rather beautiful looking deck repair causing the back end to drag. This coupled with the play in the height mechanism Greenies suffer from later in life.
But that height adjuster, if that's what we're seeing in your photos above, looks weird. Certainly not like the adjustment 'parallelogram' I'm used to seeing on Greenies.
I know not of the stallions but that doesn't strike me as the kind of thing Greenfield would have come up with. An IPC would be v handy at this point. I agree with you, it looks to me like the guy who fitted the Steel deck did this.
Are there any holes in the alloy part of the deck that suggest it was ever fitted with a more conventional setup?
Perhaps some more photos of this deck arrangement might help.
NormK #73619 13/03/16 06:04 PM
Thanks prd, this is my third Greenie and it did not look right but I sort of figures the way it was setup it was what they had copied. I have worked out how it can be done with the parallelogram to make it work but there is no indication that there was ever any mounting/pivot points fitted. I have started moving in this direction and have made up the triangles and pivot points. I will get some pics of the deck repair which has been reasonably well done, so whoever did it had a fair idea of what they are doing
NormK #73620 13/03/16 06:05 PM
prd Offline
....or perhaps I'm wrong. There's a thread from 'NeedaFixin' in March 2012 that shows a similar setup to yours.
Trying to work out how to create a link to this
It begs the question, why did they change what worked and do it like this on this model and no others?
prd #73622 13/03/16 06:41 PM
NormK #73623 13/03/16 06:47 PM
How the design was supposed to work I have no idea, it was all too rusty to bother trying to get it working. It had a spring fitted from the adjuster arm to the bolt on the same arm that I have no idea as to what it was supposed to be doing. Anyway most of that is going in the bin. Even with the plate repair on the deck it is still quite acceptable weight wise and with a coat of Hammertone I think it will look ok. It is still fully functional so I have no issues with that. maybe grind the welds up a bit
NormK #73625 13/03/16 07:04 PM
prd Offline
Yup, I give in too. Not completely sure how it works either.
I was going to make the comment that the repair could be significantly trimmed to reduce weight but if it's not too bad then well and good.
I'm curious to see what you do with the adjust lever positioning and geometry to give good operation and keep it clear of the step through area.
Looking at this I remember that when the parents went mower shopping in the early eighties to replace the old rover with a shiny New Greenie they were initially looking at a step thru model but ended up coming home with a tractor (yes folks, the one I still use smile ) because mother didn't have the strength to adjust the deck height on the step thru.
NormK #73629 13/03/16 07:17 PM
Once I get it set up I will put up some pics, it is far less complicated than what was on here and from what I have fitted works well and hopefully will adjust easily. To me the rear engines are a better simpler machine and easier on the steering without the weight of the motor sitting right on top of it. Have to admit the steering on these is not for the weak armed. I have often thought about how to make the rear end a single wheeler so the steering is much easier, and then if you were using it on hilly country you could lock the other wheel up so you have both wheels driving again. Interesting that your mother couldn't adjust the deck height and if it was this model she was looking at I can understand why,crazy idea
NormK #73631 13/03/16 07:28 PM
This is the trial fit with a piece of timber between the 2 old and new pivot points, This is in the fully raised position.
This is the fully lowered position, I have to repeat this on the other side because I can't put a shaft right through because the forward/reverse pulleys get in the way
NormK #73634 13/03/16 08:15 PM
prd Offline
That's a neat little solution. I hadn't thought of something like that.
I'm curious about where that pivot is in relation to where the parallelogram will be mounted and its distance from the centre of the cutting deck - with regards mechanical advantage. Just wondering if it's a bit too far aft?
NormK #73645 14/03/16 04:18 AM
It is going to pick up on the guide that was fitted to the deck, you can see where it was in the unpainted section. You could be right in that it might be a bit far back but I can just move the side guides back till they line up
NormK #73649 14/03/16 07:24 AM
prd Offline
Yup, I get what you mean. As you say, you can move the whole thing forward if needs be to get the balance better. That's the beauty of welded steel structure - Just about anything can be changed smile
These kinds of projects that give the brain a bit of a squeeze are a ton of fun. Enjoy!
Little_Nauvoo, Donsmowers, Tony1985, Flyingicarus, Nollzy01
18,001 Registered Users
Topics12,736
Posts106,718
Members18,002
