1 members (David Bolger),
5,308
1,338
Posts: 282 Likes: 1
Greenfield Enthusiast
Posts: 988 Likes: 7
Hello and welcome, I think your mower is an Atco. Looks to be missing it's rubber block that sits between the two claws
Have a look at this EBay auction, in the picture you are missing the part in the middle. It may be a rubber or nylon block.
http://www.ebay.co.uk/itm/Atco-B17-Commodore-EL-engine-to-drive-shaft-coulping-clutch-housing-/351627106914?hash=item51de9bda62:g:-RsAAOSwUdlWgSLY
The rest of the shaft would mount in between but the drive sprocket would be on the outside of the chassis. Hope this makes sense
Posts: 6,938 Likes: 322
Posts: 282 Likes: 1
thank's again fella's,i think i will see if i can sell the atco(it has rover stickers on it)and the second imperial,one is enough at this time,thank's again
I have pics of mine - I don't know how to download them !!
I have a pic on my ipad but when I click on all done nothing happens!
![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/01/full-8321-26701-photo_21.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/01/full-8321-26702-photo.jpg) Okay lets see if this works!!!
I think your mower is a mid 70s Deluxe B 14. There should be a brass plate under a bolt just near the starter. It should have stamped on it B14 - or B something depending on its width. I am in the middle of semi restoring mine. They are very UNpopular over here in WA. They crop up on Gumtree and most people have no idea what they are and the local workshops dont want to know about them . My dad has had one for over 40 years. They are temperamental - will absolutely not tolerant stale fuel at all and some people reckon they are too fast . I like em!!! I grew up using an Atco and dont like using the SB/Rover 45 , but I like their looks and ubiquity. Spray painted it Brunswick green and got the decal off Ebay. Its going to be my regular mower so its not gunna be showroom spec.
Posts: 282 Likes: 1
thank you very helpful i am about to paint it
Posts: 282 Likes: 1
i found the tag on the deck it has "b23" stamped,i have no idea what it means. i have nearly finished cosmetic resto i must say it is looking rather splendid if i don't say so myself... will post pic when finished,cheer's
Posts: 282 Likes: 1
hi greenpool can you post pic of chain setup,and sprocket's,i am having a bit of trouble trying to get mine right,it wont drive i have something not right thank you
Posts: 282 Likes: 1
help needed!!!i have put my drive chain's back together(many many time's)and i cant for the life of me understand this system,it wont drive at the moment have tightened/loosened chain,now let me say this i am fairly handy with the spanner's but this f@%$%& thing has sent me crazy. how does the sprocket on the crankshaft stay on!! if i turn everything by hand (machine elevated)the sprocket just undoes with the movement, i have copied the setup of pics and part's manual, i have spent more time on this than i should have,
Hello gmlI do not know if this is what you're after. This is an earlier model, but it should have the same transmission. I take it you have the primary, plate clutch working? Is there a secondary clutch (I) on the roller? ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/02/full-7392-26889-atco_ib36h_page_25.jpg)
Posts: 282 Likes: 1
Hello gml
Is it possible the bearing housing goes on the other side of the frame? i.e. that it faces the clutch from the inside.
Cheers Jack
Posts: 282 Likes: 1
Thank's Jack will try it and get back to you,just looked back at this so i guess no it doesn't go that way ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/02/full-9863-26906-full_7392_26407_clutch.jpg)
Posts: 988 Likes: 7
![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/02/full-8880-26916-image.png) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/02/full-8880-26918-image.png) My bearing is on the outside
Posts: 282 Likes: 1
Posts: 8,215 Likes: 235
What I am not seeing is what holds the sprocket on
Posts: 282 Likes: 1
that's what i want to know old mate,
If you are fitting it like that of course it will come off it needs a nut to hold it on and I'm not seeing any thread there. Sprockets are either splined,tapered or keyed and held in place with a nut as per the exploded drawing
Posts: 282 Likes: 1
it is a threaded sprocket same as reel sprocket (bottom front),tightens clockwise,not enough length on shaft for a nut,
Where are you gml, I have 620 Loctite here, that'l fix it
Posts: 988 Likes: 7
Hi GML,
I don't think your missing anything, the lower hole is probably where the bearing would mount on for another model or with a different engine fitted that would have a height difference altering the angle of the shaft.
Have you tried tightening up the sprocket then with a block of wood against it give it a hit with a hammer to nudge it up tight.
Just thinking about this quoted previously " how does the sprocket on the crankshaft stay on!! if i turn everything by hand (machine elevated)the sprocket just undoes with the movement" I'm just wondering what you are rotating by hand, if you rotate the blades it will undo the sprocket, if you rotate the shaft out of the clutch it should tighten the sprocket. Could this be what is going on?
Just thinking about this quoted previously " how does the sprocket on the crankshaft stay on!! Hi Norm I think GML did ask that, and you are quite right. The top sprocket is driven by a shaft that turns clockwise from the LH side. This means that it would always tighten a RH thread on the output shaft. This is not the same for the reel. The reel would require a LH thread because it is driven by the top sprocket. I'm hoping GML will clarify what the issue actually is. Is it: - the primary, plate clutch does not work? - the top sprocket is out of alignment? - the top sprocket won't fit the shaft? The extra cut-out in the frame is - I think - a red herring here. I cannot see what function it could have on this B23 model... ------------------- Jack
Posts: 282 Likes: 1
last night i removed all the drive chains and sprocket's will post again when i go through it all,how much cork should be on clutch plate?,,.. correct sprocket,if i tighten it too much it lock's everything up,as for the clutch, well i will let you know soon thank you all for the help,
Posts: 988 Likes: 7
I would think that the sprocket would tighten on to the shoulder of the shaft, there should be clearance. In the link that Jack supplied you can clearly see in the last pic that the shaft has some thread protruding past the sprocket once fitted up I feel your shaft needs to come through the bearing some more, if you have it apart are you able to post a pic of the end of the shaft where the sprocket screws up. I want to see the thread going all the way up to the shoulder.
Posts106,827
Members18,189
