1,199
1,113
Posts: 6,938 Likes: 317
Hello drew2229au
Yes, these had reversible reels, so the other end will also have a LH thread.
If you have the reel ground, the important thing is to fit the reel to accommodate the direction the reel was sharpened.
Hope this helps. ------------------------- Jack
Posts: 8,176 Likes: 232
This is just a stab but I would assume the other end would be R/H thread, could be wrong but that would be my guess
G'day NormYes, that was a stab in the dark  By engineering definition, the thread must be the same. Reason: when you reverse the reel the driven-side remains the same. [The sprocket is removed and placed on the other side]. Cheers--------------- Jack
Thanks Jack,
Good to know and didn�t even think about that. The leading edge would be the lower side of the two?
Hello drew2229au
The leading edge will be the higher side, with a relief angle going to the backside face of the reel.
When you have a reel ground, the vast majority of sharpeners will relief grind. You would need to specify a flat grind to get otherwise.
The reversible reel was an attempt to get extra life out of a reel between grinds. As such it favours a flat grind.
I do not recommend reel reversal on any reel mower used for domestic purposes. The better approach is seasonal back-lapping.
Hope this helps. -------------------------- Jack
Success. Managed to get it apart after the excellent advice. Now the reel and sole plate are submerged in molasses. Anyone who has a spare reel drive sprocket, could you pm me?
You got me there Jack, I never thought about being able to reverse the reel
too late to weigh in with any new information.
All that has been stated is correct.
Just waiting on my lawn coming up to a respectable level and will get a video of her in action.
I do have a spare drive sprocket. $30 + Postage. Let me know.
Hi all, I have been trying to remove the front drive shaft. I have removed the drive gear assembly and want to remove the reel drive sprocket. Problem is the drum wants to come with it. Obviously the drum transmits drive to the sprocket. I can't see any grub screws and I'm guessing it maybe splined?
Hi drew2229au
I need a bit of clarification here. What do you mean by 'the drum'?
The drum which is driven by the brake clutch shoes. In the parts list, Item number 158 is the drum, 147 is the shoes and 159 is the drive sprocket, which drives the chain, which drives the reel.
I see, So the issue is removing the sprocket from the countershaft (not the reel). The issue is, how is the sprocket (61) attached to the clutch drum (158)? I will have to defer to a Mod or a member on that. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/05/full-7392-28247-sc_detail.jpg)
Posts: 1,842 Likes: 14
G'day folks, I'd say #61 is the outer-mounted drive gear for the landroll clutch, and #159 is the reel drive sprocket here. It makes sense for that drive gear to be keyed to the shaft, with one of the #62 woodruff keys. As far as I can work this out, the reel clutch drum/sprocket assembly is free-running on the countershaft, located axially by the drive gear #61, and clutch backing plate #206 [which is also keyed to the countershaft], with thrust washers #160 and #161. Pic #2 in post #70008 back on Page 1 has a reasonable detail view of the sprocket, if it's enlarged a bit. This confirms the large diameter centre hole in the sprocket, an indication that it is most likely screwed on. SB doesn't seem to have favoured splines. As it happens, we do know the reel drive sprocket is screwed onto the hub extension of the clutch drum, from a past poster who found out the expensive way  ; https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=61229I'd expect this to have a RH thread, i.e. the opposite to the driven sprocket on the reel. Hopefully one of the past posters with hands-on experience of the Supercut teardown will chime in!
Cheers, Gadge
Thanks Gadge, I think you may be right. I have had a close look and there appears to be a thread. I have tried to turn it but it is tight. May have to get some heat into it.
Hi drew2229au and Mod Gadge
Yes, Gadge (AKA Mr Spacely from the Jetsons) has the engineering background and the skills to see this. I feel the advice on the RH thread is important here: because this is a driving sprocket (rather than driven).
Please let us know what transpires. A good photo and text will help members understand the issues.
Thanks again to Mod Gadge. ---------------------- Jack
Hello drew229au
ODK appreciates the efforts in presenting these pictures. I feel technical information on Supercuts is lacking, and these good photos help owners understand the machine.
A second person clasping the drum, as a quick mallet shock is applied anti-clockwise to the sprocket may be all that is needed to unlock the thread.
Topics13,086
Posts107,376
Members17,930
