2 members (Domenic, Olqualcast), 5,406 guests, and 2,412 robots.
by Bruce - 30/10/26 07:12 AM
#7113 11/02/08 11:58 PM
victa 160 ,the valve on the top-side of barrel maybe vaccum valve or wht ever can i block this hole off with a bolt the old unit on there is bggered,graham
gray #7118 12/02/08 01:31 AM
Chainsaw Addict
That would be the starting decompression valve, cant you just buy
another one?
gmax #7121 12/02/08 07:49 AM
Hi Gray You can use an old spark plug to block the hole .Just break the top of an old plug but you will probably have too much compression to pull it over without breaking the rope. You can get used de-compressors off Ebay from time to time . I will see if I have one in the shed .There are different lengths alo in the body.
Some of the aftermarket types are repairable . These have 3 clips ho;lding the 2 halves together and you can get a full kit at any mower shop . Cheers Joe
Joe
Joe Brown #7132 13/02/08 04:56 PM
Thanks mate keep in touch
gray #7141 14/02/08 09:26 AM
gray,
The valve cost about $7.00 and have some in stock but if it is not an after market decompresser then you will have to replace the complete unit. banghead
Not very often the valve does break but the diaphragms usually go along with the sponge filter and the replacement kits are around the $7 mark. cheers2
Bruce #7392 01/03/08 08:22 PM
Hi Gray Did you sortout the model of the de-compressor you need. Cheers Joe
Joe
Joe Brown #7394 02/03/08 12:39 AM
Gray do u need a long or short one??
Nangus, thomas18, jessesharp43, ELStretto, David Bolger
18,193 Registered Users
Topics12,767
Posts106,836
Members18,194
