2 members (AndrewRob, Bruce), 8,878 guests, and 474 robots.
Hey guys, maybe a dumb question but im trying to remove my rear wheels on my ride on greenfield mower,The model is a MK 2A 30 inch cut. 11.5hp b&s engine. The code is 11A-45193 stamped on chassie.
Ok so it has a single nut on the axle which I have removed but the wheels don't want to budge ?? am I missing something or is it just seized ?
Greenfield 30
Cox stockman 32
Yamaha supa swift
prd Offline
MOD & GREENFIELD TECHNICIAN
G'day Mike,
The single nut rear wheels are secured onto a taper with a woodruff key for location. It's an aluminium wheel onto a steel axle so we have a nice galvanic arrangement (!) and so basically the aluminium has probably corroded to the axle.
I have never removed one and have deliberately avoided doing so. That said I'd suggest gentle heating of the wheel and GENTLY trying to tap them apart. Tap the wheel as close as possible to the axle and definitely not on the rim! There are many war stories out there of ruined wheels from folks who have applied too much force with puller, press or hammer.
My two cents; if you don't NEED to remove the wheel, don't. If your trying to replace a tyre, I do them in situ.
The other thing I do is spray the area in question with wd40 of whatever jungle juice I have at the time whenever I think to in the hope that if I ever do really need to remove a wheel it may help.
I am a bit curious about you having single bolt wheels on an 11 HP machine. I thought it was only the smaller ones that had a single bolt wheel and the larger ones had the much nicer three bolt arrangement
seized on.. put nut back on till level with end of shaft, gently hit nut with a heavy hammer while pulling or levering wheel.. The shaft is tapered & has a woodruff key..
I have both set ups ( 1 nut & 3 nuts ) I do this same procedure with steering wheels also..
Hope this helps..
Paul
Such is life.......
Thanks prd and SuperDooper, yes I thought that might be the case. I think ill just leave them on until I really need to take them off, thanks again for confirming that for me guys.
Greenfield 30
Cox stockman 32
Yamaha supa swift
g'day guys, the 32" has a solid axle, ( single nut), the 34" has the 3 stud setup with the diff lock.
I always come back to an Echo
sircus, G2e, GFazz, LewisGS, mono1975
18,217 Registered Users
Posts106,871
Members18,218
