0 members (), 7,275 guests, and 1,772 robots.
#70299 02/12/15 02:07 AM
seanw
This mower has had a bad knocking noise and today died, it would seem the head gasket may be blown. i may just put a different motor on it
seems to be leaking from the head
motorwannabe
seanw #70316 02/12/15 01:07 PM
Probably just a worn gudgeon pin.
You cant just re-engine that so easily. It runs a longer crank than your regular 18" two stroke.
seanw #70330 03/12/15 01:24 AM
seanw
Thanks for the reply bigted. i have 2 of these mowers and the other one has a cracked frame where it meets the handle so i may canibalise it. how hard is it to fix the gudgeon pin problem? thanks
sean
motorwannabe
seanw #70360 04/12/15 10:16 AM
Fairly simple, remove the head, take starter off, remove bolt that holds conrod on and replace the piston, rings and rod as a whole unit. That'd be the easiest way assuming you have a good used piston there.
seanw #70361 04/12/15 10:20 AM
seanw
thanks mate i didnt really want to part the working motor from a working mower i have a few spare motors. thanks for the reply mate. i like the mulching capabilities of these mowers
motorwannabe
seanw #70362 04/12/15 10:20 AM
seanw
motorwannabe
seanw #70365 04/12/15 12:58 PM
Chinese made crap.
I'd just strip it down for parts mate. Win some, lose some. I'm sure you can sort something out though. Maybe mount a spare powertorque upside down and turn it into a helicopter. A REAL hover mower ... Paint it camo and mount a couple of machine guns on the handles. Keep the stray cats away from your yard. Just need to make it all remote control ...
If anyone could / would do it it'd be you.
Pete
seanw #70374 05/12/15 04:21 AM
its only the internals need to be swapped over mate . just take a good look in there be sure the bore isnt beyond it too or you will be swapping cranks over . might be your first full rebuild !!
not too tough a job just look and take it slowly as always
seanw #70419 07/12/15 10:18 AM
seanw
thanks for the input dave but i recon ihatewetsocks has something. i was going to swap the motors over [Linked Image]
so i will do that first rebuild later than sooner man
well i am halfway through my next project.
anyone have any really big fan blades?
motorwannabe
seanw #70720 19/12/15 11:57 PM
That oily buildup is completely normal and i suspect unrelated to your knocking. Have you checked blade disc/boss? Running lean and pinging? Personally other than scuffed pistons/bores not much goes wrong internally with these motors.
18,214 Registered Users
Posts106,871
Members18,214
