4 members (Kenniffs, Dandare, Bruce, Neill M), 9,640 guests, and 1,954 robots.
Hello,
Choke plate was found free in the carburettor.
I am trying to get it back into place.
Model: 286707 Type: 015802 Code: 9502244D
2nd image shows the shaft (should I remove the shaft?)
3rd image shows the slot the plate slides into, then a screw.
I have removed the end plate, but this will only help me replace the screw.
Anyone had to do this before?
Thanks from Mark.
I have just realised it is the throttle plate.
So my title is wrong.
Ive been reading this page.
http://outdoorpowerinfo.com/repairs/briggs_large_one-piece_flo-jet_carb.asp
If it managed to fall out I would assume that there is some combination of throttle linkage position that would allow it to go back in. Once in place a bit of Loctite on the screws should keep it there.
Yes Trev you are right.
I couldnt see an advantage taking the shaft out, the split pin was pretty hard to move aswell.
The smaller venturi stops it from the filter side.
The 3 dimples on the plate are meant to be orientated up.
The only way I could get it into the slot, was to grind the dimples on the plate down.
Working with the angle I had.
Found a screw with a tight fit and used blue loctite.
It is back together.
Neill M, Peenuke1, Purgeboi69, JackFlyers, Baga
18,240 Registered Users
Topics12,778
Posts106,882
Members18,241
