0 members (), 7,046 guests, and 1,566 robots.
G'day, I have a Masport mower here that's only a few years old and has had very little use..
The problem I have is its over revving. Now it does this even with no governor spring attached...at this stage I am wondering if it could be an internal problem with the governor? I can bring the revs down my holding the butterfly..but without holding it the engine just pulls it on full ball..
I also removed governor arm to try and fault find and I am now unsure of position it should be refitted..
I have tried to get a service manual for this engine which has left me frustrated..I am sure you guys will know whats going on, would appreciate any help thanks
You ask, ye shall receive...
Hope it's helpful...
[video]
[/video]
Paul
Such is life.......
If governor spring is removed, should the governor arm spring back by its self?
My engine is a later model than the one in the Video..the Governor arm is horizontal at the back of the engine, it has a keyed spline..
same as the video S.D put up really . loosen the nut on governor lever ,turn gov' shaft clockwise to full travel and tighten nut . throttle must be wide open .
then check throttle can be moved from idle to wide open without feeling tight or binding .
and when its setup . where the governor spring connects to the throttle plate end , the pear shaped tab there ? it can be bent gently to adjust revs . slightly bend it back towards carby side of movement , then when its up and running gently bend forwards to adjust full revs , then back to idle see if it does it well too but dont ask too much from full revs or it will 'hunt'= rev up and down . bouncing off of the governor .
just set it to idle nicely and not too high at full revs should be allgood
Yes I have done all this...when the engine is running, tightening the governor spring makes no difference because there is no resistance..the only way i can bring the revs down is by pulling the governor arm back by hand, this is why I am asking is there something mechanical internally that can go wrong with the governor?
no not normally but stranger things have happened . other than pulling it down for a looksee just check it all again to be sure .
not the carb bellcrank is sticking ? some do if working in really dusty conditions . or something bent or binding , recheck if its touching the top coweling somewhere you should feel or hear it if it is . they are easy to bend and all it takes is a small twig to hit the right spot
No, nothing is stuck...the mower is actually in really good condition...
I have tried again, following the procedure..still the same..getting a bit frustrated now...I have no issues with ripping it right apart and taking sump off...I just don't want to do this if not necessary...I wish i could find some pictures of the internal workings of the Governor of this engine so i could get a better understanding.
i do too , im sure it will be in manuals though . i dont have a book here that covers quantum and no scanner so i can anyway its just as i do when i need to but never hadto pull one down before yet . maybe a few photo's will help us work it out for you mate . or another member will have a page to show you , sorry i dont have
Thats ok, I will walk away from it tonight...maybe i can can get some pictures posted tomorrow for anyone else having this issue...
Just so we can be certain of the exact beastie we're dealing with here, there are a set of 3 numbers which are the key to Briggs engine ID. They are the 'Model, Type and Code', and will be in that order. See if you can post them up, if at all possible.
On this engine, they should be stamped in two places - the inner metal cooling cowl, above the spark plug; and on the heat deflector plate above the muffler. Rust may have obscured the latter lot, though.
I'd say that the Briggs Repair Manual you need is P/No 270962, Repair Manual Single Cylinder L-Head, if as I suspect, this is a 12000 model series side valve engine. There are a few free downloads of it around the Web, or it's available for pay [subscription] in the ODK 'Engine Manuals & Parts List' section.
The function of the governor spring is to hold open the throttle; the centrifugal governor acts against it, and backs off the throttle, as engine revs increase. The older print edition Briggs Repair Manuals had a section at the end, that described this concept very well, with diagrams. That all seems to have gone over to their Training Course Textbooks these days, though...
It is surely possible for the governor internals to fail, as it's a part of the oil slinger, that's driven off the camshaft gear. At least the slinger gear is plastic, and on the Quantums the camshaft gear is too, IIRC.
Hey again..sorry for late reply..I have come down with the flu and have been sick as a dog this week..Here are the engine code numbers..
2H802-3123-B1 03060259
So is it safe to say that if you take the governor spring off, the revs should drop or stall the engine?
Hmmm miss a digit 12H802-3123-B1. And Gadge got it right on the repair manual 270962
This is from another post I made to a Briggs & stratton engine infomation site.
Originally Posted by SuperDooper
I found this site very handy for Briggs specs & Infomation..
[color:#3333FF][size:14pt]Briggs & Stratton Info[/size][/color]
Paul
Such is life.......
Just opening this thread back up as I have finally got back to this mower...I have opened the sump up and found the Governor oil slinger to be broken..
Can anyone help me with a part number? and maybe tell me the best place to get one online?
I think this is the correct part, but as i dont seem to be able to find my engine number on any lists I am not sure
http://www.ereplacementparts.com/slingergovernoroil-p-251355.html
Recycling and Repairs
[quote=AVB]Hmmm miss a digit 12H802-3123-B1. And Gadge got it right on the repair manual 270962 [/quote
If you double check the engine number, you will find that AVB has it right, and the manual you want can be found on the Briggs and Stratton website below: -
http://www.briggsandstratton.com/us/en/support/manuals/results?NTT=12H802-3123*
Direct link to the Illustrated Parts Manual for the 12H800 series engine Types 0652 through 6699, where you can locate the specific part number is:-
http://bsintek.basco.com/BriggsDocumentDisplay/18hvCCXHnfBhU7y.pdf
I can't find an exact IPL for your engine via any of the Briggs websites I use.
But you could always get a quote from the ODK Shop - there is a new parts search facility, that finds your exact engine model.
BTW, you'll need a new crankcase gasket too.
Once you have the part number, it's a matter of doing a Google search on it; e.g. as 'Briggs XXXXXX'.
There are two traps with US internet suppliers.
One is that many don't ship outside the US, but you have to dig into their shipping info to find that out.
The other issue is that shipping can be very exy; US Postal Service [USPS] is almost always the cheapest option.
It's often easiest to search on eBay US; sellers usually say if they offer international shipping, and have a postage calculator in their ad.
Sorry, I wasn't quick enough to edit the above.
Briggs and Stratton require a 6-digit (Alpha/Numeric) Model number, so when you only noted 5 earlier, there was one digit (or letter) missing.
Note: Some of the early Model numbers only had 5 digits so, in these cases, you need to add a zero "0" in front to make up the 6th digit to allow a search.
You can save and use this link for future engine searches:-
http://www.briggsandstratton.com/us/en/support/manuals/engine
The above search uses the 6-digit model code and the first 4-digits of the Type, then you pick the engine relative to your final code number.
In your case, you enter 12H802 in the Model search box and 3123 in the Type search box and press enter. The result will give you two engine variations. These being 12H802-3123-B1 and 12H802-3123-E1.
Your engine is the first on the list and you can download the Illustrated Parts List and/or the Operators Manual specific for your engine.
As an extra bit of information, the Engine Code 03060259 is the date and factory of the engine. The date in the first 6 digits in YYMMDD format, being 2nd June 2003, and the last 2 digits are the factory, being Factory 59.
Hope this is of assistance.
You are correct in the Part number for the Oil Slinger, according to the above link, is 691997.
I have searched the ODK Parts Database, as suggested by Gadge, but it is not listed as an item stocked, so have found the part in Australia for $45 plus P&H from [Censored] at:-
https://www.[Censored].com.au/genuine-briggs-stratton-slinger-governor-oil-691997.html
Otherwise, eBay seems to be other option. None listed in Australia, but they are listed on our eBay with indicative P&H charges.
The Part Number reference appears to be common to a large number of engine variations and models, and being a Genuine Briggs and Stratton part, one would expect the part to remain identical.
Folks, here's another useful site for Briggs parts lists: http://bsintek.basco.com/MDEXResultsPages/default.aspx
This one only requires the 6-digit Model Number, but may require looking through a few results pages to find the Type, or one that's close.
AVB had the correct Model/Type number above, with the missing digit.
Strangely, I couldn't get the results to come up the first time I tried http://www.briggsandstratton.com/us/en/support/manuals/engine earlier today, but it works fine now...
Anyway AlwaysTinkerin, you're all set now, with the confirmed part number.
Thanks guys, I did check that out my self and yes it appears to be the right part number...buying from the US through the link i posted gets it here for 39 bucks au...I would still like to pick something up cheaper than that if i could...thanks for your help, very informative , nice work
I tend to compare eBay pricing against an Australian supplier (where possible) along with consideration to the P&H costs and time frames. Quite often, I'll take the Aussie supplier, if for a little more cost, over an international supplier, due to possible return purposes and speed of local delivery.
I'd consider the A$39 against A$45, and for the extra $6, it's generally a mater of logistics.
If I was buying several units, then I'd take the international option as being cost effective.
Worth getting a price quote from the ODK Shop too, I'd say. Even if it's not a stock line.
Even the Kiwis have these for cheap; http://www.sesdirect.co.nz/slinger-governor-oil/ grin
I am all for supporting Australian sellers Bushy..and I am always happy to pay extra for an Australian made anything...but I get the feeling they have put a huge up mark on the part given you can buy it retail for around the 10 dollar mark overseas...I am looking at Amazon actually, I think i will make a list of other stuff i need and take advantage of the free postage.
You can't always support local sellers, I wanted a stator for my Honda a few years ago, Honda here wanted $550 for it, I got one from the States for $125 delivered
25 bucks to the door from Kiwi land, cheers Gadge, that'le do
joemowsbest, greenback, Jett lang, Rover45Restoration, seebok
18,206 Registered Users
Topics12,771
Posts106,862
Members18,207
