Rating: 5
#6771 30/12/07 11:44 PM
Hi: Yep, another 'can't get the cord to retract'. Have tried rotating clockwise etc but no tension at all on the cord, just turns motor over. I'm guessing that the spring is broken/kaput. How do I access the spring to check this out?
Lian
Lian #6772 31/12/07 12:25 AM
Lian,
Ok you will have to undo the three(3) bolts holding the starter on the housing and remove it.
1. Then you will need to undo the shaft in the centre of the starter (use a spanner or shifter).
2. Then lift off the the plastic pulley and the spring is underneath it.
3. If spring is broken then replace it.
4. When fitting the starter back replace the 'O' ring.
We have more detailed information including pictures under parts list and manuals area. cheers2
18,212 Registered Users
Posts106,871
Members18,213
