2 members (Pazzaboy, beam),
3,677
333
Posts: 715 Likes: 1
seanw
The back wheels turn fine with no bad sound i am scared about pulling it apart just to see
motorwannabe
does it look like it leaked ? i think but not sure just full of grease , so if its not broken .......... just need a belt then
Posts: 715 Likes: 1
seanw
it doesnt look like it has leaked cant remember where i put the belt but will look tomorrow. too bloody cold man. I am only a couple of steps away from getting this one going. Am watching rambo to inspire me. cheers mate
motorwannabe
he would have just shot off the boss hahaha
Posts: 715 Likes: 1
seanw
I did enough damage to it too belive that
motorwannabe
Posts: 715 Likes: 1
seanw
Vccomm they have different shaft sizes i cant fit the pully on ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22761-dscf4774.jpg) What to do? is there an adaptor boss??
motorwannabe
so same length but different diameter ? well now we both learned something .. so now its looking like you do your 1st tear down see whats wrong inside which isn't normally too much aaaaaaah , i found before the side pulls did have a different crank though , do you have another good side pull 80 series ? if so , check that out , one here but too hard to send up there
Posts: 715 Likes: 1
seanw
I did but i pulled it apart to put the first one together aaahhhh. its practice i suppose
motorwannabe
seems so yes . its tinker time !! nice to know what the noise was though huh
Posts: 715 Likes: 1
seanw
I have been thinking all day about this issue. 1. can I just use the smaller boss. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22765-dscf4775.jpg) 2. Weld a couple of beads around it to make it fit.
motorwannabe
nope , it will weaken it and distort it too so if it does go back on might never come off again . just pull the head n barrel and have a little looksee , even totalled inside you can use everything from other engines except the crank . new bearings and seals and you have yourself a new engine for very little cost maybe $40 at most if no piston n rings are needed
Posts: 715 Likes: 1
seanw
and i thought i was onto a winner. no easy fixes in this world
motorwannabe
still could be , easy to rebuild these jiggers , just dont go welding stuff !!!  look inside , see what damage their is , cant be much really
Posts: 715 Likes: 1
seanw
this is it. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22766-dscf4777.jpg) .
motorwannabe
cant really see a problem in thar , so what was the noise you told about ?, already 20 thou over too , so if piston is still good you need to stick with it . looks a tad dry though . pic' of inside the head too ? i'll tell you why later if we like whats there  the noise wasnt just a badly fitted or bent cooling cowl ? (black tin top cover) that head gasket is home made too , who's been in there tinkering huh
Posts: 715 Likes: 1
seanw
Yes i recon the noise was the cowl, ps. I made the gaskets out of the cardboard in the middle of a vb 30 block. I dont trust this carby. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22767-dscf4778.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22768-dscf4782.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22769-dscf4780.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22770-dscf4781.jpg) Found scratches on the cowl.
motorwannabe
was a good guess then !! so engine is ok then . goodo , so just get the correct gaskets , you can see already she's gunna blow !! if you like to use the g3 then remove the plastic adapter and go for it need to use the throttle cable too though to suit . so yup , change those gaskets vb's a great beer but it dont have that many uses  any air leaks will upset it so while you have the boss off do the bottom seal too then should be good to go  ps , std head sorry hehehhee
Posts: 715 Likes: 1
seanw
As i have no other gaskets, read somewhere that i could use it as gasket paper. even cornflake boxs?? i want to change the carby, does the plastic adapter come out easy? ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22773-dscf4785.jpg)
motorwannabe
2 screws and it pulls off , and yes you can use GASKET paper but correct thickness and top of my head i cant remember but its thinner than a c/f box
Posts: 715 Likes: 1
seanw
so i tighten the hell out of it??
motorwannabe
Topics13,076
Posts107,348
Members17,905
