0 members (), 393 guests, and 1,884 robots.
Masport Shitemaster 720 blade
#64611 31/05/15 11:32 PM
How are you guys prepping all the rusted parts for painting / assembly ? Mainly items like the rear rollers and sole plate etc , the ones that are covered with years of surface rust .
jim13 #64612 01/06/15 02:31 AM
Hi jim13,
Basically most of us use the sand blasting process to clean everything perfectly.
BB
jim13 #64616 01/06/15 07:04 AM
There's also the slow, low-tech approach to rust removal. grin
It looks like this: [Linked Image]
And it does smell about the way it looks! Definitely outdoor use only.
What this is, is a bath made up from stock feed grade Black Molasses and water. I've seen mix ratios from 1+5 to 1+10 molasses/water recommended, but this 1+10 one is working just fine for me. Made up by weighing the molasses into the plastic bath [a cut-down 25L polycube], then adding a bucketful of hot water, stirring, and topping up from the garden hose.
I cover it with an old washing machine cabinet panel, to keep insects etc. out [and spray around it with Surface Insect Spray for ants].
One of the main advantages of this method is that it will only remove rust, and won't corrode good metal, if the workpiece is left in a bit longer than optimal.
It does take a while; up to a few weeks, for heavily rusted bits. Those will also require periodical removal from the bath, and scrubbing off the loosened rust with a nylon brush, a few times.
jim13 #64677 03/06/15 02:28 AM
Looks like a messy process ! I did consider using some phosphoric acid from bunnings but used a sandblasting place instead. Just picked up everything from them. Everything nice and clean but leaves a rough finish.
Is it recommended to paint the rear roller gear things and key pieces ? I was going to make them smooth and paint them.
jim13 #64850 10/06/15 04:50 AM
It's not all that messy really; just hose off the bits on the lawn, then scrub them down.
After all, DIY sandblasting is pretty messy too, unless you have a blast cabinet.
I do have the gear, and garnet grit, on hand for sandblasting. But if I'm not in any hurry, the molasses bath is just fine.
jim13 #64887 11/06/15 08:23 AM
You can also use ELECTROLYSIS. This involves running a DC current through an electrolyte of washing soda, it's really simple and only requires a large tub, a car battery charger/battery and some washing soda. Check the net for detailed instructions.
Craig
Keep On Truckin'
Shehdhhe, Bigredmowerguy, astfgl, Bendhaven, Sam Hood
18,060 Registered Users
Topics12,746
Posts106,765
Members18,061
