1 members (AMP), 4,443 guests, and 1,212 robots.
Can anyone on the board tell me how to compression test a single cylinder mitsubishi generator engine with soft-start incorpoated i.e how do you disable soft start so that you get true compresion test rather than a false reading. I can't find any visble mechanism such as a decompressor externally. any ideas gratefully accepted
thanks, NZ635
nz635,
You will not see a decompresser as it is in the valve lifter system. cheers2
Thanks Bruce, so if you were doing a compression test how would you go about it in order to get a true reading?. Can you over ride the valve lifter, or is it a case that you can't actually perform a compression test
Thanks NZ635
nz635,
If you pull the engine over a few times you should get a reading unless the valve clearance is not correct or the head gasket is leaking.
Is your reading over 70? cheers2
Thanks for the info, i'll give it a try and get back to you if it isn't over 70- have a good day.
NZ635
Moderated by  Bruce, Mr Davis
18,159 Registered Users
Topics12,760
Posts106,815
Members18,160
