0 members (), 4,930 guests, and 451 robots.
by NormK - 01/12/25 05:15 PM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
by NormK - 05/12/25 10:14 AM
Lectron Generator Fuel Pump
I have a brush cutter that has a TM 24 Mitsubishi motor and it has started to leak up behind the motor, do I have to separate the motor to get the tank off as there are no screws, just some holders on either side of the motor which seem to clamp on to the fuel tank. It seems to be leaking at the top area where it looks to be repaired on the tank photo. What do you use to reseal it [Linked Image]
You will need to remove the engine cover,starter assy and maybe crankshaft access cover. The tank is just held in place with rubber bushings.
[Linked Image from i1329.photobucket.com]
As for gluing, this is HDPE plastic and there is not much of anything that I know short of plastic welding that actually bond to the plastic.
Ok Thanks for for information
17,712 Registered Users
Topics13,031
Posts107,110
Members17,712
PHP: 8.3.26 Page Time: 0.031s Queries: 21 (0.027s) Memory: 0.6252 MB (Peak: 0.6473 MB) Data Comp: Zlib Server Time: 2025-12-08 13:05:44 UTC
