1 members (Red Rum), 5,195 guests, and 1,133 robots.
Hi Everyone, my father in law is keen to replace my Kirby engine with a Honda. The Kirby needs a fair bit of work to run perfectly (he is an old school perfectionist mechanic :))
What model/s of Honda engines are most suitable? Sorry if this has been asked somewhere else.
Krusty
Hi Krusty, there has been at least one other discussion on which Honda to use, but it was a brief reference and there's no harm in bringing it up so that more people get their chance to express their view and experience.
Reel mowers do not consume much power, except to drag themselves up hill: they are usually pretty heavy compared with a rotary. You didn't tell us the width of your father-in-law's SB45, but if it is 14" or 17", I suggest a Honda GX120. It is rated at 3.5 horsepower net (not gross, as the original engine was). Even for a 20" it has more power than the original engine that was fitted. It also runs vastly better than a Kirby Lauson, I agree with your father-in-law on that subject. Its disadvantage is its price: you can buy a side valve Briggs for much less, and while a Briggs is no Honda, it does run far better than a Kirby Lauson.
If you are concerned to get the best value engine possible, I suggest you get a chonda (an unlicensed Chinese copy of a Honda). They are even cheaper than a Briggs, and run as well as a Honda, while the base engine has Honda's superior durability as well, but the disadvantage comes in the bolt-on parts of the engine. The starter, governor plate (external speed control mechanism), air cleaner and muffler usually do not exactly follow the Honda design, and may give trouble. Furthermore parts may not be easy to get. The base engine parts are not a problem, since they are interchangeable with Honda parts, but this is not true of some of the other parts. (Of course you can nearly aways fit the whole Honda system, but unless you had a junked Honda on hand, that would be unaffordable.)
You will find that the cheapest, easiest-to-find replacement engine is a chonda version of the Honda GX160. This is a bigger engine than the GX120, rated at about 4.5 hp (gross is 5.5 hp, and net is not given in the specification). The chonda version has the same advantages and disadvantages as the chonda version of the GX120. More importantly, it is a bulkier and heavier engine than the GX120 (though not as heavy or bulky as the Kirby Lauson) and you might find it fouls the handlebar, so you should check this before making a purchase.
Remember, while all the engines mentioned will bolt straight onto your engine mountings and the crankshaft extension (PTO) comes out in the right place, the length, diameter, and even shape of the PTO is subject to multiple options, so you have to choose the right one. Two sizes of engine-side clutch-half are available as SB spare parts (5/8" and 3/4") but this won't help if you buy a metric shaft-size, or one that is tapered, or doesn't have a keyway, or even has an external thread. Understand what you are buying before you buy it.
Hi Krusty, Just to let you know that my own Scotty 45, a 17", Series 2, twin rail machine has a Honda G100 2.5HP fitted and I have never looked back...My particular model Honda is no longer available, but it bears out what grumpy has said, cylinder mowers do not need the same amount of horsepower as a rotary to do the job....
Honda....first pull starts...every time, if carefully maintained...
Thanks for the replies. My fil is a big fan of Honda engines for exactly the same reasons you are. He's also adjusted my lap blade and reseated bearings. Great to have a skilled and passionate mechanic/engineer to sort out my SB
Hi Krusty, and thanks for the reply...Don't forget to let us know your progress and please post plenty of pics as you go along. wink
This will make a good archive for the forum, and hopefully help another member who wishes to do the same conversion. grin
18,189 Registered Users
Posts106,827
Members18,190
