0 members (), 4,599 guests, and 908 robots.
#56959 15/07/14 06:47 AM
hi all ,I have a white ride on with a 5 speed variable speed, its very hard to get into gear still drives when the clutch is engaged, they are all original belts in good order, would any one how to do the adjustments on these, thanks micka
micka #56970 15/07/14 07:10 PM
micka, we would need to know the actual model number to have any hope of helping with this.
micka #56980 16/07/14 06:12 AM
that's the problem I'm having too, grumpy, the tag with all the imfo has worn to cannot read state and the decal on the bonnet has worn, I will try and post some pics though, its a 12.5 briggs motor and a 32'' cut, thanks grumpy
micka #56987 16/07/14 06:37 PM
When you post some pictures, both general ones of the machine and specific ones of the clutch and belts, someone may be able to identify it for us micka. Meanwhile, I suggest you take a look at all of the White owner manuals, and see if there is a recognisable picture and description:
http://lawnandgarden.manualsonline....ite_outdoor_lawn_mower_product_list.html
The owner manuals also tell you how to make adjustments to belts and clutches, and include Illustrated Parts Lists, so if you can find the right one, it will probably solve your problems. Please come back and tell us how you go, including your actual model number, plus pictures of your mower and its belts and clutches. We have very little information on White products, and members will be interested.
micka #57092 21/07/14 03:00 AM
hi Grumpy, I found an adjustment on the gear selectors, put the machine in neutral and the gear lever in the dead neutral position and adjusted, this fixed the staying in and not selecting problem. I had the pulleys and springs off when my brother showed me a spring that the end broke off once, he made a new hook on the end and put it back, making it shorter than original, I replaced it and every thing is all good, working as it should. Not much wrong after all but enough to put every thing out of order, if he hadn't have came over when I had it in bits I don't think I would have noticed it, thanks for your help Grumpy
micka #57093 21/07/14 03:23 AM
Thanks for reporting back, micka. However now I'm not clear on whether you have adjusted the selector to compensate for having a modified spring, or you fitted a new spring as well as adjusting the selector.
micka #57105 22/07/14 06:47 AM
hi Grumpy, yes fitted a new spring as well as adjusted the gear selector
micka #57117 22/07/14 06:39 PM
Thanks micka, that completes the thread - I'll close it.
18,147 Registered Users
Members18,148
