1 members (Fusion27), 5,118 guests, and 391 robots.
by NormK - 01/12/25 05:15 PM
by NormK - 08/12/25 07:03 PM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
by NormK - 05/12/25 10:14 AM
Lectron Generator Fuel Pump
Hi All, I was given this Ryobi brush cutter not working and am trying to bring it back to life. I have never had one so all new to me.
When I received it it was all covered in oil. I expected there was a leak so cleaned it whit a degreaser solution. I emptied and washed the fuel tank which had some melted rubber ring inside (maybe from the cap) on very old fuel.
i took the carb out and it seemed clean, so did not want to mess with the gaskets or diaphragm as i saw someone in youtube saying Ryobi doesn't provide kits anymore. The carb is a WT148A I then replaced the air filter (made my own out of foam) as it was almost non existent Checked the spark plug and looks clean and new. I investigated the petrol/oil mix and the recommended seems to be 25:1 so went to bunnings and bought the Ryobi 2 stroke "high quality" oil and prepared a small amount of fuel for the initial test.
After a few tries I managed to get it running but it died out after some 10 seconds or so. I never got to switch the knob to the run position. The problem seems to be a large leak showing at the exhaust. I opened it up, removed the plastic cover at the back (where the air filter is held) gave it a wipe and tried to start it with the cover off. this was not a good idea as it seems to shoot fuel out of the carb (through a hole which would be normally blocked by the choke knob.
When I took the cover off, there was a small amount of fuel around the carb but the exhaust had a lot more. I am not sure whether the leak is in the exhaust or whether it is dripping into it from the carb (which is located right above it) I managed to get the cutter started a second time but again died after a few seconds. Once it dies I had to try hard to get it to start again and the fuel seems to be pouring out of the exhaust.
So, does the fact that the cutter starts mean I don't need to replace the carburator? I realised the WT148A has been discontinued and I would have to get a WT148-1. I suppose it will be similar
this may seem like a silly question but if the leak is in the exhaust, how can all that fuel make its way there without the engine even starting? is the carb doing what it is supposed to be doing? I must clarify there is no priming system on this equipment.
Thanks in advance for your help!
Some photos below
The first thing we need to get straightened out is your starting technique. Brushcutters, chainsaws, and other tiny 2 strokes that use all-position diaphragm carburetors pretty much all start the same way. You turn on the ignition, set the throttle to the start position, apply full choke, use the primer if it has one, then pull the starter several times briskly. If all is well, after about three pulls the engine will start then stall after a very short time - usually less than a second. You then open the choke to the part-choke position if it has one, or if it hasn't, open it to about 3/4 choke. Leave the throttle in the start position of course. Then you pull the starter again. Normally it will start on the first pull this time, since it has a belly full of fuel from the full-choke run it has just done. After somewhere around 15 seconds to 1 minute running that way, you will notice some smoke in the exhaust and it is time to open the choke fully. Then all should be well, though you may have to wait another minute before it will idle (meaning, you wait before you release the throttle from the start position). Don't let it idle for long, even after warm-up, or you'll probably foul the spark plug.
From your description you have been keeping the choke applied. Consequently raw fuel was ejected into the muffler and a few other places.
Please try following the above instructions, and tell us what happens.
Hi Grumpy, thanks for your reply.
I had been following the instructions on the sticker as follows;
-switch on
-choke in full choke position
-pull a few times until the engine sounds like it wants to start
-move knob to partial choke
-a few more pulls (sometimes it started here, but with a quite a bit of effort)
_then I was supposed to let it warm up for about 10 seconds before moving the knob to the run position but did not have the chance as it stalled before that.
There was smoke on start up and came up very noisy. Not sure if stalling was due to me relieving the throttle trigger a bit or to do with the fuel leak issue.
Other thing i noticed is the rope getting too hard to pull sometimes and sometimes it would be too lose as if something came undone inside. After a few pulls it was back to normal.
Most fuel seems to be dripping at or from the exhaust but I guess it could be the carb which sits directly on top. I took the plastic cover off to observe the carb when I pulled the rope, and that is when I saw fuel being ejected. yes the choke was on as recommended in the instructions.
I will follow your advise and give it another go today.
First, you must not "relieve the throttle" until the machine has warmed up - probably for at least a minute on zero choke. Open the choke to the partial position after its initial burp-and-stall. Then start it, and open the choke the rest of the way ASAP. If you do it too soon, it will stop. If you do it too late, it will smoke, spew fuel out the exhaust, stall, and be hard to start again. At this point it is possible that the fuel "leak" you have might be just over-fuelling, resulting in raw fuel coming out of the muffler and the engine rich-loading and stalling.
These things are not easy to use, it takes practice to make them run at all and then they are still pretty ordinary compared with the worst 4 stroke lawnmower you will ever see. There is a reason that so many contractors use the Honda 4 stroke trimmers: they may be heavy, and expensive, but they are very easy to start, and you can let them idle without them fouling the spark plug.
st one more question.
Is fuel meant to enter between the membrane and the metal plate with four screws in the photo below?
I opened the carburator up again today and although I can't remove the membrane and gasket on this side of the carby, I noticed they get moist (some fuel remaining in the carby from yesterday) when I press the membrane. I thought this may be normal (overflow release or something) as there is a little hole on the plate which aligns with where the membrane gets moist. I can't see the perforations in the membrane so they may be very minute.
On the other hand, if this is not normal then I may have found the source of the leak.
You may, Jonez, we need to see some pictures to even guess. There are two diaphragms on the carburetor: one for the fuel pump, and one for metering the fuel. The one with the punched steel cover with the hole in it, that is retained by 4 screws, is the metering diaphragm.
thanks grumpy, yes the meetering diaphragm is the one that permeats fuel. Is this normal?
I just called the Acacia mower Centre in Brisbane to inquire about the kit or even gaskets for this carb and the guy did not want to know anything about Ryobi. Told me it was better to buy a new cutter. Wouldn't even tell me if if had any other carburators that may work.
Sorry, I did not see you reply. we must have been typing at the same time. Taken: what you say makes sense. The engine was rich and hard to start. However the leak starts from the moment i pulled the cord the first time it seems. It seems that was the problem the previous owner had. I got it completed bathed in oil/fuel and had to give it a good clean before I could put my hands on it. I also suspect the two big gaskets in the photo may need replacing.
If the fuel is coming through the metering diaphragm, it needs to be replaced. This is easily done - that is a Walbro WT carburetor, and a standard kit for it looks like this:
http://www.ebay.com.au/itm/Walbro-c...DefaultDomain_15&hash=item19e3ec1005
This fits both WA and WT carburetors (the two most common types), and contains diaphragms and gaskets only. For a higher price you can get replacements for more parts. The bits that don't fit your carburetor will be for a WA. Just put them back in the ziploc bag and forget them.
Note the kit has both conventional and mylar fuel pump diaphragms. The mylar ones are used for American fuel, which commonly contains ether (MTBE, TAME, or whatever). Ether destroys conventional diaphragms.
The kit does not contain a replacement metering needle. Inspect your needle and see if the Viton seating part (black rubbery bit on the pointy end) is worn. If it is, you need a more complete kit.
The two gaskets in your photo are Ryobi parts, not Walbro parts. If they need to be replaced, you may have to get them from a junked whipper snipper.
thanks a lot. I am getting there! So it seems the meetreing diaphragm is perforated. It is hard to see though. It just gets wet when I press it down. It is also stacked to the carb, so I haven't removed it yet. The carburetor is a WT-148A superseeded by WT-148-1 . Apart from ebay is there any other way to get the kits? Are there Walbro distributors around? I was looking at their web site but did not see anything in Australia
You can get Walbro parts through the Outdoorking online store.
Some mower dealers keep the kits and some don't. I don't know of Walbro distributors who will deal with the public. Generally, the online store will be considerably more knowledgeable and more helpful, but there is a minimum mail-out fee of about $20 that hurts unless you buy a fair amount of stuff in a single order. It is great if you want a fairly expensive part, or for the people here who work on lots of engines and have a reasonable throughput of parts. Obviously dealing with a helpful expert is way better than dealing with someone who is neither of those things.
Here is what a WA/WT overhaul kit looks like, rather than just a diaphragm and gasket kit:
HERE
It has a metering needle, metering lever, and some screens and welch plugs.
Thanks very much. I have just ordered the kit in your first link (D10-WAT). only over $7. Checked the needle as you suggested: it was'n black but seemed very good. Checked the ebay store from your the link you posted and realised they also had D10-WTA @ $4.80 which seems to have all i need for now, except that the diaphragm looks made from a different material. For the full kit I see they have the K10-WTA. ($13.50) This would have also been under $20 Thanks again, I will patiently wait for my order to arrive. I will put the cutter together and will update the results then. cheers
The fuel pump diaphragm in that $4.80 kit is mylar - it's intended for use where there is ether and/or ethanol in the fuel, as in the US. I haven't tried using a mylar diaphragm - I've seen scattered reports that it is more troublesome than the conventional one, in that it doesn't always work when installed as casually as a conventional one is installed. Since your metering needle is OK, and you don't have signs of lean mixture, you have a good chance of success just by replacing the metering and fuel pump diaphragms with conventional ones the same as the original ones. There are no indications of any problem with your original fuel pump diaphragm, but since you will have a new one, and they do age, it seems appropriate to fit it in the interests of long term reliability.
Got the kit today and realised it was not the closest to my carby. I know you linked D10-WAT for information only but that is also the kit Walbro recommends for WT-148-1, which is the carburetor that superseded mine (WT 148A).
I had a quick look again and it seems D20-WAT was what I needed. The metering diaphragm is the correct one but the conventional fuel pump diaphragm is not the same. However, the mylar diaphragm suits perfectly. I am now thinking: I could order a new kit, I could leave the old fuel pump diaphragm on or I could use the mylar type.
Looking at the old diaphragm, I see it is not very good flexible so perhaps I will try the mylar type and see what happens.
Sorry Jonez, I had not noticed that the two fuel pump diaphragms for WTs were of different designs. Your old diaphragm has stretched to a saggy/baggy condition and I would not re-use it. In that situation I would certainly use the mylar diaphragm. Just be careful to fit it correctly, it is a lot thinner and more easily wrinkled/folded/ creased than the conventional type. With correct fitting I'll be surprised if it does not work properly. Please let us know how it goes of course - I don't recall a thread featuring a mylar diaphragm, so a lot of people will be interested in your experiences with it.
Hi Grumpy.
Happy to share my experience.
Based on your previous comments I was unsure the mylar diaphragm would work so I decided to put the new conventional diaphragm (top left marked with and x on the picture above) plus the mylar one at the bottom right in the photo. I realised that if I superposed them I would get just the shape I needed. Besides, I wouldn't be adding much to the thickness of the set given the mylar is very thin. I thought if they sealed right there was no reason why this shouldn't work. I used the conventional diapragm first to close the valves on the carburetor and then mylar on top just to close the part marked with the X.
On the weekend I tried starting the cutter a few times but nothing. Good thing is the leak has stopped. This morning I emptied the tank and put the carburetor apart. It did look very dry. Like if no fuel had gone through it at all.
Put the old pump diaphragm and gasket back in it fired up. Used for about 20 minutes in which time I turned it off and on a few times (only gave me troubles once) It was all good until I bumped the head for more string and it stalled. There was still fuel in the tank but could not start it again so left it alone for now.
I still think the mylar diaphragm or the arrangement I had set should work. I noticed I had set the trigger cable a bit too long and perhaps this is the reason why it did not start before.
Next I will use the mylar diaphragm only and see what happens.
17,712 Registered Users
Topics13,031
Posts107,109
Members17,712
PHP: 8.3.26 Page Time: 0.047s Queries: 56 (0.039s) Memory: 0.7401 MB (Peak: 0.8622 MB) Data Comp: Zlib Server Time: 2025-12-08 10:04:26 UTC
