1 members (Dandare), 4,707 guests, and 1,687 robots.
#5233 10/10/00 06:41 PM
Having difficulty removing Clutch drum screw(recessed)Is this a LH thread? Is there a special tool/procedure in removing this stubborn screw ? Thanking in anticipation.
john I
john I
#5234 13/10/00 12:34 AM
Use a #20 Torx driver, hold the flywheel with
a screwdriver against the housing, turn
clockwise. If you have not already destroyed
the grip inside the screw this will remove it, these are never easy, good luck.
Bill
Bill Greer
#5235 21/10/00 08:13 PM
John,
The safest way to undo the screw is put some starter rope down the plug whole to the exhaust port side. Then place a # 20 screw driver into the screw and tap it with a hammer to relieve it. Then you should be able to undo the screw without to much problem.
18,157 Registered Users
Topics12,759
Posts106,814
Members18,157
