0 members (), 1,301 guests, and 1,020 robots.
My Hyundai Mower is surging.
by aLaw13 - 20/04/26 01:29 AM
Rover height adjust plate
by Bruce - 07/04/26 03:39 PM
YardKing 4 stroke spare parts
While rebuilding my VC160 Mk1 I was looking out for parts. I found new old stock blade plates and they are green. One had blades fitted and showed marks from being fitted but blades were near new. I fitted it up and found it was bent, maybe the mower was dropped when new. Fitted blades up to one of the others and it was perfect.
G'day Paul
That's a great story. smile
I don't think blades were ever fitted to service blade holders.
But I'm not sure ...
Your anecdote rings true to me.
That was a good find.
Victa actually did have complete blade holder assemblies [i.e. blade holder factory fitted with blades] available, up to the early 1990s at least, going by the parts lists I have access to.
In fact, along with quite a few of the later blade holder types, the earlier 9C type blade holder wasn't available bare - it came with 9-150 cutter blades fitted, and could also be ordered with side [assembly P/No 9-172] or rear [P/No 9-173] discharge blades fitted too.
My family's OPE shop used to keep a few of the 9C's in stock in the 1970s, for retrofit to Victas that came in for service which still had the 9B holder fitted.
I like that one better than the fancy twisty metal design that replaced it. I seems to cut better due to it's simple design. Was all that hi tech fancy mould work designed to stir up better air flow to send the clippings to the catcher?
MF, you are probably right, somebody came up with the later blade carrier design claiming it would create lift and it probably does, but when you look at the Rover carrier that remained dished and the clippings still ended up in the catcher. And then you have the ones with just the straight bar blade and those clipping end up in the catcher as well
Spot on their NormK
G'day MF,
Yep, that was one reason; another 'selling point'...
Introduced for the 1974 season; https://www.outdoorking-forum.com.au/forum/u...atalogue-victa-1974-range.html#Post62200
Victa didn't get it quite right first time around though; the blade holder pictured in that brochure was recalled, and is fairly rare now.
That 'wave' design had a tendency to bend the crankshaft end, if it copped an object/obstacle strike.
While this problem was well known with Masport 4-strokes [which used a bar blade], it was new to Victa.
Consequently, that holder design was superseded by the 'swirl' design.
17,930 Registered Users
Topics13,086
Posts107,376
Members17,930
PHP: 8.3.30 Page Time: 0.041s Queries: 29 (0.034s) Memory: 0.6595 MB (Peak: 0.7134 MB) Data Comp: Zlib Server Time: 2026-04-25 00:37:07 UTC
