3 members (leslloyd, Mike33, RodRover45), 1,297 guests, and 850 robots.
Scott bonnar 33 Roadside find
by Mike33 - 15/11/25 02:34 AM
by leslloyd - 14/11/25 05:45 PM
Cone siezed on PTO Shaft
by ToryC - 12/11/25 02:18 PM
Kirby HK30 Governor oil leak
Tanaka TBC2251
Star Poducts cylinder mower
by leslloyd - 15/11/25 11:02 AM
Buying a cordless trimmer
by maxwestern - 15/11/25 01:07 AM
by Bruce - 14/11/25 10:58 AM
by Magilla - 12/11/25 09:10 PM
Lower Crank Seal - Sprint 35
by AVB - 12/11/25 10:13 AM
Tanaka TBC2251
GCV 160
by NormK - 11/11/25 08:22 AM
Originally Posted by Joe Carroll
Its not a powertorque at all.
Thanks Joe.....I think I shall stick to Scott Bonnars from now on.... lol
Originally Posted by tiger
Thanks Joe, have had a look at the crank seals, no leak there. What i did notice though was that the carby body leaked a small amount of petrol. The g3 carby is made up of 2 halves separated by a gasket. I changed the gasket, lapped the carby, tightened the 2 screws as much as they could go but a small amount of petrol is still getting out which means there is a small gap there, could that be the air leak? I can't tighten the screw anymore, what can you do to make it air tight?
There are gasket sealants out there, not sure if they work well with petrol, anyone had any experience with them?
Tiger,
to set up the G3 carb governor remove the little cover to expose the bevel and pinion gears , hold the throttle arm and governor arm in line with the gear cover screw holes , if the gears are set correctly there should be one tooth of the beval gear visible to the right of the pinion gear.remove beval gear and adjust as needed, make sure that the butterfly is shut when adjusting the gears
Thanks Mitch, did pretty much as you've explained, only thing is not sure that i had the butterfly shut when adjusting. Really appreciate your help on this one.
this should solve your issue or at least give some amount of control, the position you set the gears up in is the stop position so its necessary that it be closed on setup.
hey how did you go with your g3?
Hi Mitch, have got throttle control so can control the manic revs now, when i get close to full throttle it still revs a little too high for my liking.
You should now be able to adjust rpm with the little gears set under the vane there
is a marking there when lined up that's factory setti.g
Hi Gents
I have a mark 3 victa utility 160cc mower. I have looked at this page but note that mine has the white governor vane. It used to run fine but at the moment is is either running around idle or then at high revs. i have adjusted several times but just cant get it right. does it show the correct position in the repair manual (happy to buy) unless there is a set of fotos that show the adjustment.
Appreciate any further assistance.
tortron, Mike33, ChadTimmo, leslloyd, gkov3
17,668 Registered Users
Topics13,021
Posts107,027
Members17,668
PHP: 8.3.26 Page Time: 0.046s Queries: 34 (0.039s) Memory: 0.6669 MB (Peak: 0.7335 MB) Data Comp: Zlib Server Time: 2025-11-15 00:14:24 UTC
