5 members (AMP, Red Rum, MowingManiac, 2 invisible), 226 guests, and 539 robots.
by NormK - 01/12/25 05:15 PM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
by NormK - 05/12/25 10:14 AM
Lectron Generator Fuel Pump
Page 5 of 6 1 2 3 4 5 6
Blumbly #49264 08/09/13 03:17 PM
Originally Posted by Blumbly
Heck yeah I'd even go to the trouble of honing the bore.It would certainly help.
Can't hurt so will do, have a honing gadget with 3 stones here somewhere, think I bought it do brakes but never used it for that purpose.
tiger #49266 08/09/13 04:07 PM
hey there ,
those rings are rooted ! that gap is rather excessive a hone and some new ones certainly wont hurt it. ill post the hose and rings on Monday man.
should make a fair difference, give your piston a good clean , a light wet and dry to tidy up the scoring , and clean the ring gaps out, base gasket weeping is okay they don't often blow out base gaskets.
a light hone to scuff up the bore and and a good clean , also clear any carbon build up in the exhaust port.
tomo4192 #49268 08/09/13 04:29 PM
Thanks, Tomo, I guess I'll need two gaskets, one for the head, the other for the crankcase, I'll pick those up at the mower shop, is there anything else I need? Do you think the worn rings account for all the problems I've had with this mower?
tiger #49269 08/09/13 05:06 PM
hey , yes you will require top and bottom cylinder gaskets that is about all.
by the looks of the rings there is a chance they are causing the issue , ive replaced rings in better condition that have caused issues, your symptoms and previous diagnostics's points to them.
cheers mitch
tomo4192 #49275 09/09/13 07:14 AM
cheers mitch
Thanks Mitch, just thought i'd ask the question since i have now taken the machine apart so if there was anything else i needed to do eg bottom seal then i' d do it now without having to dissassemble later.
tiger #49281 09/09/13 10:28 AM
If you wish to change bottom seal now is the time if its
soft and clean i wouldn't worry about it
tiger #49282 09/09/13 11:47 AM
Its soft and dry, there was some leakage between the crankcase and cylinder though.
tiger #49284 09/09/13 03:00 PM
sounds okay to me man , id leave it be
tiger #49292 10/09/13 10:52 AM
Noticed that on the bottom ring there is what I thing is called a ring expander, it's a corrugated foil-like object, does that stay or is it removed when I put on the new rings?
tiger #49296 10/09/13 05:05 PM
they normally dont fit with new rings and does no harm not being there , if the new rings dont come with them i normally don't worry about it
tiger #49297 11/09/13 03:31 AM
Rings are designed either to use expanders, or not use them. If they require an expander, in my experience they are sold with one. You should never use an expander with a ring that was not designed to use one. Hence my system is, if the ring is sold with an expander, always use it. If it is sold without an expander, never use one with it.
grumpy #49303 11/09/13 10:52 AM
Thanks Grumpy, I'll take the expander off as the rings I'm getting don't have an expander.
tiger #49329 13/09/13 04:26 PM
Thanks Tomo for the rings etc. I've put the rings onto the piston but cant get it into the cylinder because there's not enough room for the piston ring compressor. The connecting rod/piston is still connected to the crankcase. Would i be correct in saying that i have to put the piston into the cylinder and then connect the piston into the connecting rod or is there an easier way?
This operation is much easier on the powertorque!
tiger #49331 13/09/13 07:33 PM
tiger, with a bit of patience and perseverence you can compress the rings with your figers(top one first, then bottom one after you've pushed the top one through) and get the piston assembly in the bore. It helps to have the crank turned to a position where it allows the piston skirt to rest on top of the crankcase.
Alternately you can remove the gudgeon pin to remove the piston from the rod and do it that way.
Either way works, i've never used a ring compressor coz i never had one that small. Just make sure you size up your rings in the bore prior to assembly to make sure you have enough end gap; I've had a situation in the past where the rings were too tight in the bore(no end gap)and had to file the ends down a touch.
tiger #49335 14/09/13 04:20 AM
Thanks Ted, not sure my ring compressor is small enough either, forgot that these are the small rings. Did try with the fingers but didnt get anywhere.
tiger #49337 14/09/13 02:40 PM
Had to take the piston out and once I did that I got the rings and piston into the cylinder. Re-assembled it all and put a little petrol in but it didn't start, yanked the starter cord a few more times but no start mad
So I can rule out compression. It now leaves fuel and spark. I put a tablespoon of fuel into the spark plug hole and it still didn't start so I guess it must be spark. I tested the spark and I noticed that sometimes it sparked but at other times there was no spark. It was inconsistent and these results were outside of the cylinder so under compression I guess the results would be even worse. Bruce mentioned the condenser, I notice that the condenser has 2 wires attached, one goes to the kill wire. There is a electronic terminal at the end, question is how do I replace the condenser ie what do I do with the wires? The photo shows the terminal, looks like the wires are crimped and soldered. [Linked Image]
tiger #49339 13/09/13 11:03 PM
hey tiger ,
least we know the rings are good now , when you buy a new condenser it normally comes with the wiring attached just make sure you get the one to suit g3 carby. if your going to do condenser do points also they may be floppy.
tiger #49340 14/09/13 01:07 PM
Rings are definitley good, I can feel a little extra effort when I pull on the starter cord. I'm yet to get the condensor and I read a previous entry on this forum about no spark with points/condenser where the user said that the key in the keyway of the starter mechanism was not engaging the cam, I looked at mine and exactly the same situation so I made sure it was engaged, also adjusted the points (yet again) and got a better spark. As soon as I got the better spark I knew it would fire up and it did, but the tickler on the carby is not releasing any fluid so I've gone full circle on this mower. I assume that the needle is stuck in its seat so I'll look at that later. I am also noticing that there is a spark coming from the bottom right corner of the mower chassis, it's not everytime that I pull on the cord but approx 50% of the time. I have insulated the kill wire and still this mystery spark is there, what is causing it and why is it only happening on some of the pulls?
tiger #49342 14/09/13 05:03 PM
Strange man , voltage leaking from some where .
check your plug lead and kill wire for broken insulation
tomo4192 #49343 14/09/13 05:21 PM
Thanks Tomo i looked at these first, there is no broken insulation, havent seen this before.
17,712 Registered Users
Topics13,031
Posts107,110
Members17,712
PHP: 8.3.26 Page Time: 0.067s Queries: 55 (0.055s) Memory: 0.7308 MB (Peak: 0.8276 MB) Data Comp: Zlib Server Time: 2025-12-08 22:12:39 UTC
