2 members (Sdjr, 1 invisible), 544 guests, and 806 robots.
by NormK - 01/12/25 05:15 PM
by NormK - 09/12/25 09:14 AM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
by NormK - 05/12/25 10:14 AM
Lectron Generator Fuel Pump
Page 1 of 6 1 2 3 4 5 6
#49042 31/08/13 04:39 AM
Tired of stuffing around with the old one, am after a G3 carby with governor attached.
tiger #49045 31/08/13 08:08 AM
If you like you can send them here and I can put them on a running mower and see how it goes.
Blumbly #49047 31/08/13 09:08 AM
Yeah might do that but mine will not work, there's either still a blockage (unlikely because I've cleaned it 3 times) or the float mechanism is faulty.
tiger #49051 31/08/13 02:06 PM
Well I'm happy to give that a go if you like.Just give me a PM if you want and we can work out the details.
tiger #49053 31/08/13 03:18 PM
Just remember the jet because. its 125 cc
tomo4192 #49057 31/08/13 05:29 PM
Well that's OK I will be trying it on a 125cc.
tiger #49064 01/09/13 05:55 AM
Try these steps for the G3 Carby:
1. Check main 'O' ring on the brass jet.
2. While main jet is out check that the two holes are clear.
3. Make sure that the seat has not moved otherwise it will flood.
4. Check governor vane is in the correct position.
Once you explain a bit more I will give you some more tips to fixing a G3 carby, cheers2
Bruce #49066 01/09/13 07:57 AM
Thanks Bruce.
Carby appears to be flooding as plenty of petrol around where the gasket separating the 2 parts of the carby is. The tickler mechanism releases a lot of petrol and it goes everywhere, hard to tell whether petrol is leaking from gasket or overflow from tickler.
1 o-ring appears to be fine
2 2 holes are clear as they have had carby cleaner put through them as well as compressed air as well as thin wire.
3. Did take the seat out for better cleaning, feels firmly back in but how can i be sure?
4 governor works when i move the vane but when i move the throttle, the butterfly valve sticks, cannot see why, how is governor vane to be positioned?
Any help appreciated as i think i'm close but mower starts and dies after a couple of secs.
tiger #49067 01/09/13 10:29 AM
tiger,
The reason that your are getting fuel leaking is because:
1. The seat is not sealing properly and this can be caused by the the float having fuel inside it.
2. Needle and seat damage.
3. Your fuel release primer is touching the float causing it to stay open.
Once the fuel issue is fixed you should have the mower running properly and if not we will look at the governor issue next. cheers2
Bruce #49068 01/09/13 10:37 AM
Thanks Bruce, pretty sure float is ok ie no fuel inside it, have inspected it for leaks, cant see any.
Point 2, how can i make an assessment on this or do i just replace both of them?
Point 3, can anything be done about this, perhaps twist the tickler slightly away?
tiger #49073 01/09/13 03:11 PM
Had another look at the carby, the o-ring had a slight flat edge so i replaced it, also lapped the carby faces, had to use the same gasket because all the mower shops were shut. I tried to start the mower but no success.
tiger #49074 01/09/13 03:45 PM
Well the offer still stands.As I have no ideas left.
Blumbly #49076 01/09/13 03:57 PM
Appreciate it but i think i might be closing in on the problem eek
Will let you know.
tiger #49077 01/09/13 05:30 PM
How to test the needle and seat you will need to remove the base cover of the carburetor and then turn it upside down with some fuel line on the inlet. Then suck on tube and put tongue on end of tube, if suction holds then the needle and seat are ok providing the tickler is not touching the float.
Note if the tickler it touching float the test is a waist of time. cheers2
Bruce #49082 02/09/13 06:02 AM
Since taking the carby off again the mower will not start. Despite putting in some fuel into the spark plug hole or using start yr bastard (i know i shouldn't use it but it started and ran with this goo), i cannot get the mower to run. Spark plug is slightly wet so assume it's flooding. Let it dry out overnight , tried this morning, still did not start. This morning i put compressed air through spark plug hole, carby and exhaust hole (which was also wet). Still no start.
Bruce, tried the needle and seat test, seems to be ok, also from what i can tell tickler is not touching the float. Compression is fine, still getting spark at least on the outside, have to assume its still flooding but how long does it take before the flooding airs out?
tiger #49083 02/09/13 09:30 AM
i had one bought here for the same sort of thing , just kept pulling it for a while with plug out and lead away from fuel spray !!! left it in the sun a few hours and it finally chugged itself back to life , smoked like h#@&+* too for 10 mins and allgood . seemed they left fuel on so almost a full tank went through it . g3 it was too , the guy lost the small button on top of tickler and put a nut on it !!! so as bruce said , it was holding the float down a touch wink . still has a spark , nice and blue ?? cheers2 , Dave
vccomm #49084 02/09/13 10:14 AM
I've tried some further diagnostics, i had someone hold the fuel tap while i held the carby and manipulated the float. The needle was closing ok. I noticed though that the spindle holding the float came off easily. I had some brazing rod so i cut up a bit and its now a nice tight fit within the carby body. I reassembled it and put it back onto the mower. I pulled the cord a few times and left the mower out in the sun for a few hours and it started but died soon after. Tried a few more times and it ran for several secs, best result yet, the throttle had no effect on the revs and it sounded like it needed more revving but i couldnt give it any more because of the governor. I tried a few more times to get it started but it wouldnt. Now have i got a flooding problem or is carby blocked again?
tiger #49089 02/09/13 03:22 PM
it may have the jet out of a 160cc , causing the flooding. the fact the plug is wet means the crankcase compression is ok .
tomo4192 #49090 02/09/13 04:06 PM
Interesting theory. Plug is wet but i don't understand how you can conclude that the crankcase compression is ok from that.
tiger #49092 02/09/13 05:32 PM
because as the piston goes toward tdc , the crank case is under vacuum fuel is drawn from the carby into the crank case , then as the piston travels down the fuel air mixture is compressed in the crankcase then as the port opening is uncovered by the piston the fuel sprays into the combustion chamber . no crank case compression no fuel will get into engine
17,712 Registered Users
Topics13,031
Posts107,111
Members17,713
PHP: 8.3.26 Page Time: 0.065s Queries: 56 (0.055s) Memory: 0.7330 MB (Peak: 0.8469 MB) Data Comp: Zlib Server Time: 2025-12-09 05:13:16 UTC
