2,920
1,589
Posts: 612 Likes: 1
This mower has been sitting at my sister's place for a few years. It always looked daunting because it was a little different to the mowers that I tried to fix. The snorkel is cracked in a few places and I have never been able to get a spark on it. I assume that it's got a condenser/points, will I need to take the flywheel off it and how hard is it to do so? Also need a snorkel how hard are they to get? ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2013/07/full-2318-11759-mower_001.jpg)
Professional Tinkerer
I'd guess the points just need a simple cleaning to get a spark... And for a snorkel, Cant you basically you use any sort of hose? Kori
all victa parts will fit it if there from a fullcrank , but i think it would be a 125 ? plug not in the middle of head ? points are under flywheel yes and almost any victa snorkle will fit , good old machines though have one here too , still starts and runs sweet and easy . not really worth much but i did see one go for i think $180 on ebay a while ago !!! and it said it needed work too
Posts: 4,291 Likes: 4
How can you tell from that angle it's a 125cc vccomm? Sorry but I think it could be a 160cc as well.Could be either I guess.Also I'll have to disagree there with you vccomm yes and almost any victa snorkle will fit I know a VC-160 and such alike won't fit.Heaps more of an angel to the other way,but should be able to find one surely,maybe.Can they still be able to get new ones?Strongly agree with vccomm of where the ignition is.Now your original question,Is it worth it? Well I guess I would put it into 3 category's. Which comes to what you want to do with it? 1.To fix and sell: I don't think you'll get a lot for it. 2.To fix and mow lawns:why not. 3.To fix and put in a personal collection: I guess that's up to what you want in collection.
i dont know for sure yes , but as its identical to mine i think it could be a fair guess . sorry i didnt make it clearer though
Posts: 612 Likes: 1
How can you tell from that angle it's a 125cc vccomm? Sorry but I think it could be a 160cc as well.Could be either I guess.Also I'll have to disagree there with you vccomm yes and almost any victa snorkle will fit I know a VC-160 and such alike won't fit.Heaps more of an angel to the other way,but should be able to find one surely,maybe.Can they still be able to get new ones?Strongly agree with vccomm of where the ignition is.Now your original question,Is it worth it? Well I guess I would put it into 3 category's. Which comes to what you want to do with it? 1.To fix and sell: I don't think you'll get a lot for it. 2.To fix and mow lawns:why not. 3.To fix and put in a personal collection: I guess that's up to what you want in collection. Thanks for the comments guys. The question I posed was based on roughly how long it would take to get going and whether a snorkle could be easily found as I don't think this one can be repaired. Not sure about selling it, just the challenge of trying to get it to run but I don't know whether I want to spend more than 6 to 8 hours on it.
Well it would depend on what is wrong with it as to how long you want to spend on it.I understand where your coming from there.(It's like I have just picked up a Victa 4 stroke.Now somebody has painted with an oil based paint with brush.Now it won't run,so I have to work out how much I can get for it,then work out how long to get the paint looking right,how long to get it running and then take that from what it's worth (carry the 1).I can see that this one may not be worth the time and effort).So back to yours so yes I know exactly what you mean,however there is the fun and the learning more about them to consider.You should be able to find another hose,I just don't know if you could find a new one any-more.I don't think you would spend that long fixing it though,you could change the whole ignition over in much less time than that.At the end of the day I guess it depends on whether you want to do.That's the more important question.I know you'll work it out.
Small Engine Technician
Blumbly if the hose is the same diameter as the new victa power torques, then you might be able to find it at your local mower shop. I know we keep a long roll of power torque snorkel in stock, and you cut it to suit the customers length. I can't find it on Bruce's shop, so if its the same snorkel and you want a new one, a local mower shop is the way to go.
The cheapest and best way to get powertorque snorkel hose is by buying a grey water hose from the reject shop, 8 meters for around $5, the hose fitted to this mower is easy enough to find or they can be repaired as I have seen before.
Its most likely a 125, as that cowling has a bump for the decompressor, on the back whereas most 160's have a slightly bigger cowling.
Posts: 64 Likes: 1
as for the snorkel, try the ga spares website they have these snorkels listed then take the part no to your local dealer and get them to order a snorkel for you
Is someone going to help tiger to take the Flywheel off correctly. That would be a good start . Tiger I would try to get spark first and to do this mate you need some help in taking the flywheel off first. Do you have a Flywheel puller if not you might be able to get one from outdoorking store. To take the Flywheel off it's probably easier to see how it's done on u-tube or someone on here that knows how to explain it a lot easier then I can. So if you wold like to get it going this is where I would start.
The flywheel is not to hard to get off ,get the nut off for now..And let some WD40 soak into the sharft for a few days...Just dont use a hammer to smash the flywheel off like some ..
Posts: 64 Likes: 1
if you have access to a rattle gun this is the best way to remove the flywheel. plus you should have little trouble finding ignition part for these if necessary
might not be the best way but it always worked for me , i just use a rattle gun seems to work well it lossens it as it undoes the nut with vibrations , but NEVER!!!! use it to tighten again as it will break the flywheel . if that doesnt work then use a puller after a good soak with crc or the like
Posts: 612 Likes: 1
Thanks so much guys for those ideas. Have only taken one flywheel off before and that was a few years ago, only thing I remember was that it took me ages to do it. Joe, like the idea of the hose bought from the Reject store, that is really convenient as I have a Reject store close by also a nice cheap solution.
Sorry tiger ,before you take your Flywheel off you might want to check for spark with your killwire disconnected from the carby then if no spark then take the flywheel off and check your points etc! Also check with a known good spark plug. Id like to help you through this but there are much more qualified 2 stroke pushers that will be able to guide you better mate , cheers and good luck.
Posts: 612 Likes: 1
Thanks Roebuck. I did try a good plug but still no spark. Will try without kill wire connected but carby is different from the usual 2 stroke stuff I've done.
metal carby ? only one wire on it , just unclip it and make sure it doesnt touch any other parts but normaly the old girls dont do it often . a knowen good plug isnt a new one though , i know i have had a few bad new ones ! normaly keep a good used one for tests and check it once in a while . how you getting on with it ?
Posts: 612 Likes: 1
Thanks Vccomm, makes it sound easy. Will check it out, can't do anything for next few days on the Mayfair but will let you know how I go with it.
Yep sounds like there could be an ignition problem. Have you got the flywheel off yet. Could be the points cap not being the right size. I'm glad vcoomm that I'm not the only one to have faulty new spark plugs.
Posts: 612 Likes: 1
Without the engine running the decompressor is open so there will be no compression . try unscewing the decompressor and plugging the hole with a spark plug then compression will be felt
Posts: 612 Likes: 1
Tried that but forgot to mention it in the previous post.
sounds like it needs rings man. still think its worth while provided the cylinder is ok
Posts: 612 Likes: 1
Thanks tomo, i neglected to say previously that with the muffler off the piston looked in reasonable condition and the rings were free moving. The bloody thing feels like its got plenty of compression but the gauge shows nothing.
the compression wouldn't be as high as your average car engine 125psi - 195psi so as long as you had two resistances one hard and one soft it would be fine. as far as spark goes, sounds like the wire you reconnected was the kill switch. remove the flywheel and give your points a light file or polish with fine sand paper. you should then get something , dont often see coil failure . cheers,tomo
Posts: 612 Likes: 1
Hey Tomo, how hard is to get the flywheel off on these mowers?
Not to bad with the right tools normally a 3 leg puller will do the job theyy do have a tendancy to seize on the crank, some times they lift off by hand
Posts: 612 Likes: 1
Flywheel came off easily, no puller needed. Bit lost what to do next. The points were fairly clean and the condenser looks new. I was expecting there to be dirt and rust but not the case. Gave the points a slight sand with very fine sandpaper. Anything else I should do before putting the flywheel back? Perhaps I should start a new thread on this as it's moved away from the original focus? ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2013/08/full-2318-12357-mayfair_points.jpg)
hey ! glad it came off easy . the points look fairly healthy . one check before you put the flywheel back on is adjustment . pull your spark plug out and stick a screw driver on the piston at top dead center, mark the driver shaft then mark 3mm back toward you allow the piston to travel back to the 3mm mark on the screw driver (anti clockwise) 3mm before top dead center the points should just be starting to open , also just rotate the engine until points are open and check the gap it should be .020" (thou). should have spark after the points clean
Topics12,746
Posts106,765
Members18,069
