1 members (Red Rum), 3,304 guests, and 419 robots.
by Bruce - 28/11/26 12:52 PM
Much appreciated blumbly.
Hope it all works out for you.
G'day have unseized a few engines over the years, although they had cast iron pistons.
the best method i have found is soaking in automatic transmission fluid for around a year and then hitting piston out with a sledge hammer and a block of wood.
in your case you might damage the piston, however if you shaped the end of the piece of wood to be a snug fit in the bore and hollow out the end of the piece of wood so that the force is directed to the outer part of the piston (strongest). Set the barrel up on blocks with the conrod hanging down and then give the wood a good strong hit with a heavy hammer. If you can it to move a fraction the battle is won and would tap out fairly easily. Another thing that helps too is heat up the barrel etc in you bbq, take it out and poor some icy water into the underside of the piston to shrink the piston a bit. hope that makes sense.
smash the piston from the inside out with a small pin punch, then you will be able to cut most of the way through the skirt with a hacksaw blade enough to get it out without damaging the bore enough that a rebore wont fix, oversize piston and rings, problem solved.
Scotty's gone quite for a few days.I'm getting worried about the acid part now.Did you try and did it work?
G'day All,
I have started, punching through the top of the piston but haven't got any further, i need to get back into it.
Since then iv picked up another rotomo, and a unknown brand mower, ill post some pics on the weekend for you guys. Iv got to stay away from swap meets!
Scott
Hi Scott,
Did your restoration ever Progress?
18,248 Registered Users
Topics12,780
Posts106,888
Members18,248
