4 members (Camdawson, MowingManiac, Deejos90, Dandare), 7,489 guests, and 336 robots.
The bends in the snorkel?
Is it possible to still buy the cam that sits over the crankshaft and if not is there a way you can fastened the cam so it has no movement at all?
Ignore that last paragraph as I was not rite in the head . Ya have them moments.
Giday ,I cannot find a coil in store for this mower does anyone know where I might pick one up or a link as the one I'm after has two terminals and canno. Find on outdoor king store.
a coil like this one will work though you will have to re route your tension cable underneath. as it protrudes from a different angle.
http://www.ebay.com.au/itm/VINTAGE-...mowerAccessories&hash=item35c8d1a9db
Thanks gizmo,you where right about the coil being good . I put a new key in the keyway this fixed the tiny bit of slop the flywheel which ment a more stronger and even blue spark so that ment the coil was good. I also tested with a multimeter and was good reading also. I then cleaned the carby and tested the float and needle worked ,put it all back together and it runs really good. Miracles do happen . Great little mowerThankyou heaps for all the knowhow.
Hi,it sure is a great little mower. wink
17,607 Registered Users
Posts106,905
Members17,607
PHP: 8.3.25 Page Time: 0.041s Queries: 27 (0.034s) Memory: 0.6502 MB (Peak: 0.6865 MB) Data Comp: Zlib Server Time: 2025-09-30 09:39:00 UTC
