1 members (1 invisible), 6,941 guests, and 298 robots.
Hi,
I have a vanguard powered generator come into the shop as it surges?? I have checked valve clearences, striped and cleaned the carby and everything seems fine and the engine seems to have done very little work... It starts easy and then the revs just go up and down... I assume it is something to do with the governor.
What it does... so you start it and the engine just pulses... it revs up the governor kicks the throttle back and then as it is dying the throttle shoots back up and the process repeats...
Any help would be appreciated, I don't have alot of experience with governors...
Hi mrintenso, there are two standard causes of a petrol engine hunting, or cycling in speed continuously with a cycle duration of perhaps about 2 - 5 seconds. By far the more common one is lean mixture. The less common one is mechanical binding of some part of the governor mechanism - for example a tight spot in a pivot, or a link rubbing against an adjacent part.
Because lean mixture is far more common than a governor fault, I suggest you begin by checking for that. I know you have cleaned the carburetor, but there are other possible causes of leanness. I suggest you proceed as follows. Ensure there is no load on the generator. Start and run the engine, and when it begins to hunt, choke it slightly. Vary the amount of choke you apply and see if you can get it to run smoothly without hunting. If you can, the problem is lean mixture, not a governor fault. If you can't, we can discuss some less convenient possibilities. Please report back in detail, with pictures, on this initial test.
17,605 Registered Users
Posts106,900
Members17,606
PHP: 8.3.25 Page Time: 0.038s Queries: 19 (0.027s) Memory: 0.6189 MB (Peak: 0.6365 MB) Data Comp: Zlib Server Time: 2025-09-29 23:02:14 UTC
