2 members (Dandare, looktall), 5,954 guests, and 2,042 robots.
by nath - 16/10/26 10:48 AM
#45575 30/04/13 04:51 AM
does anyone know the name of the tool required to unscrew the magneto bolt from a victa commando ????
r4d2 #45576 30/04/13 05:05 AM
G'day Arthur,
yes, the magneto is underneath the engine on a power torque engine.
It should not require a special tool to remove it, as it is just 2 12 mm bolts. I normally use a 12mm deep socket, I think the later models are 11mm.
r4d2 #45577 30/04/13 05:11 AM
There is also a full crank comando
thanks tomo the model i have has a collar with a recess drilled into it so that you need a curved tool with a short 6mm shaft to fit the recess im sure ive seen a similar tool somwhere but just cant remember where
r4d2 #45579 30/04/13 06:31 AM
A photo would be great, the only thing I have ever needed to get a magneto off any victa engine is a socket set and a screwdriver.
r4d2 #45584 30/04/13 08:59 AM
i know ive seen the tool looks like a scimitar with a half inch dowell at the end it wraps oround output shaft hooks in2 the collar and has about a 5" handle
r4d2 #45591 30/04/13 04:44 PM
If it's a newer power torque engine all you need is a hammer to give the boss a good whack,same way as you get the boss off a full crank engine...[Linked Image]
r4d2 #45602 01/05/13 05:37 AM
thanks chris thats the one !!! looks pretty clean mate
mreddie, Matfew, Grahamp, ttvgcm, DeanVR4
18,161 Registered Users
Posts106,819
Members18,161
