1 members (reggieb), 1,692 guests, and 2,662 robots.
by FiM - 12/09/26 02:12 PM
by mower1 - 05/09/26 05:51 PM
by NormK - 24/01/16 02:46 AM
by NormK - 12/09/26 07:48 PM
by NormK - 09/09/26 05:07 PM
#45575 30/04/13 03:51 AM
does anyone know the name of the tool required to unscrew the magneto bolt from a victa commando ????
r4d2 #45576 30/04/13 04:05 AM
G'day Arthur,
yes, the magneto is underneath the engine on a power torque engine.
It should not require a special tool to remove it, as it is just 2 12 mm bolts. I normally use a 12mm deep socket, I think the later models are 11mm.
r4d2 #45577 30/04/13 04:11 AM
There is also a full crank comando
thanks tomo the model i have has a collar with a recess drilled into it so that you need a curved tool with a short 6mm shaft to fit the recess im sure ive seen a similar tool somwhere but just cant remember where
r4d2 #45579 30/04/13 05:31 AM
A photo would be great, the only thing I have ever needed to get a magneto off any victa engine is a socket set and a screwdriver.
r4d2 #45584 30/04/13 07:59 AM
i know ive seen the tool looks like a scimitar with a half inch dowell at the end it wraps oround output shaft hooks in2 the collar and has about a 5" handle
r4d2 #45591 30/04/13 03:44 PM
If it's a newer power torque engine all you need is a hammer to give the boss a good whack,same way as you get the boss off a full crank engine...[Linked Image]
r4d2 #45602 01/05/13 04:37 AM
thanks chris thats the one !!! looks pretty clean mate
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30
SeanClaude, fullcranky87, DonD, abigliazzi, I@mthej9
18,117 Registered Users
Topics12,754
Posts106,797
Members18,117
