1 members (1 invisible), 1,878 guests, and 594 robots.
Bushranger cylinder mower
Acrher Chainsaw Chain
by AVB - 21/01/26 09:00 AM
Model number - where is it?
by Koii - 12/01/26 12:06 PM
Sanli Redback Ret Spring
by NormK - 22/01/26 02:05 PM
by NormK - 21/01/26 09:55 PM
Rover Thoroughbred Model 85
#44006 12/02/13 05:11 PM
With these engines. To shut the motor off is that controlled by the throttle cable in the carby or by a kill wire? Cause i got it running sweet but wont turn off. An i cant get the cable to pull back any further lok. And theres a cut wire
Hi Nathan, there should be 2 wires going to the socket on the RHS of the carby. Its a standard setup for the G4/LM carbs. On the full crank motor, one wire goes to ground on one of the bolts on the blower housing and the other one comes from the coil. You'll need the carby cutout boot and grommet but they're fairly cheap.
Would you happen to have a picture of the wire setup. Just so i can get a idea smile
hey it seems your also missing a decompressor.
wire set up pics ,
one wire from under the flywheel and one to ground under one of the cowling bolts
Thanks i will try get that setup smile an yea i think ur right with the decompressor cause that makes it easier to start? An when i pull start it there is alot of pressure on pull start if that makes sense
yep thats what its there for . it also stops the engine from flooding
I had a look an i dont think theres ment to be a decompresser there?
17,805 Registered Users
Topics13,058
Posts107,236
Members17,805
PHP: 8.3.28 Page Time: 0.048s Queries: 29 (0.043s) Memory: 0.6528 MB (Peak: 0.6866 MB) Data Comp: Zlib Server Time: 2026-01-23 09:14:19 UTC
