0 members (), 704 guests, and 1,870 robots.
Masport Shitemaster 720 blade
#423 10/10/00 05:41 PM
Having difficulty removing Clutch drum screw(recessed)Is this a LH thread? Is there a special tool/procedure in removing this stubborn screw ? Thanking in anticipation.
john I
john I
#424 12/10/00 11:34 PM
Use a #20 Torx driver, hold the flywheel with
a screwdriver against the housing, turn
clockwise. If you have not already destroyed
the grip inside the screw this will remove it, these are never easy, good luck.
Bill
Bill Greer
#425 21/10/00 07:13 PM
John,
The safest way to undo the screw is put some starter rope down the plug whole to the exhaust port side. Then place a # 20 screw driver into the screw and tap it with a hammer to relieve it. Then you should be able to undo the screw without to much problem.
18,062 Registered Users
Topics12,746
Posts106,765
Members18,063
