2 members (adz, DFB),
1,454
1,526
I have a Victa Vortex and i was wondering why they have the hard rubber thing around the outside of the blade cutter deck , if i was to put a new blade cutter deck on without this rubber thing what would be the out come ,
70s & 80s Victas
Sounds like your mower has the wiz bang Victa turbo disc! I think it is supposed to assist in the vacuum lift of the grass into the catcher but I am sure it's more marketing than actual performance. I doubt putting on a standard Victa 2 stroke disc will see any difference so Id go for it!
Collecting Victa 2 stroke mowers from the 70s and 80s.
Posts: 4,291 Likes: 4
That would be good to find out again.I do remember being told what the idea was but I can't remember what it was again.So it would be good to have it here for future reference.
Posts: 523 Likes: 1
Yea cause vortex rev lower cause they cause vacum an lift an blow grass into catcher instead of mower pushing grass in catcher
Thanks guys for the quick reply , this is just a new project i have started on and have'nt had the mower going before this , I will keep the old blade cutter deck ( which is nearly stuffed ) and when i get the mower up and running i will see how it preforms ,
Posts: 523 Likes: 1
Is it the disc with the squarish holes in the disc?
Posts: 523 Likes: 1
Oh yea vortex turbo disc think its called :-)
Posts: 1,819 Likes: 6
The early vortex had a different disk with very short blades. It was pressed steel. Have a couple here but dont have a pic. The later Vortex (and the V40) had the 'turbo disc'. It is flatter than a regular oval disc and it has a large black rubber fan bolted to the disc. I think it was also used on a couple of different steel base models. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2012/10/full-4181-8489-9oct12_004.jpg) And minus the rubber fan the disc will work on a full crank utility with the short blades, the handle bolts foul on the normal oval disc. The early utilitys had a smaller round disc and longer than normal blades. There is nothing to stop you changing to a regular oval disc. I would also suggest you try a later 4 blade disc as well. The regular oval disc with the later high lift/mulch (the wide ones) blades goes ok too. Just two of them is enough to blow the back door part open at full song. So the blades in the pic above on a normal disc.
Thanks Rodeobob for the info and the pics , Very much appreciated
I had a Victa Clubsman in the shed last night. Steel base mower, rectangular cover with built in tank. Flipped it over and it had the same blade plate as the 'turbo disc' but with no holes for the rubber fan.
So it looks like this disc might have been used on the low end mowers.
Found this pic on my computer. This is the Vortex disc. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2012/10/full-4181-8565-scrapfind1_005.jpg)
Hi David,  on an excellent result! As this thread is complete, I will now close it.If any member has anything to add, please PM a moderator.
Topics12,748
Posts106,775
Members18,090
