2 members (Michael D, Buckets),
5,050
1,140
I have this old Victa I bought about 12 years ago for $10 from an opshop. I thought it probably wouldn't work but it's been running like an absolute champion ever since. Problem is, it recently stopped working. No spark. I suspect it needs new points. Could someone be so kind and identify this model for me. I've tried to find this model myself on the internet but haven't had any luck. Thanks.
Posts: 2,738 Likes: 6
I think that's a 1974-1978 V167 125cc Utility.
There is a serial number stamped on the crank case, any chance you can get that number up here, that will help.
Cheers Ty
Thanks for the quick reply. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2012/03/full-5758-5512-serial_number.jpg) 017002340 Thanks
Yep, that's a V167. yours is a Late 77 model.
The Carby should be G4 (Though often replaced with LM by now)
Anything else you wanted to know about your Utility 125?
Cheers Ty
Thanks Mr Davis,
I just wanted to know the model to a) satisfy my curiosity and b) hopefully restore this beauty to her former glory. I hope to clean her up and put some new parts on her. Are all serviceable parts available for this motor?
I love this mower. Except for the fuel nozzle getting blocked occasionally, which is a simple fix, she has been exceptionally reliable, starts 1st or 2nd pull, and mows through just about anything I aim her at.
You should be able to find most parts for this mower without any hassles, If you have any troubles with any parts, Jump on and let us know, somone should be able to help you.
If you like, I can see if I can track you down a chute flap for the side, I have on here, which works, but is a little cracked, or I can see if I can find you one in better condition if you would like?
Cheers Ty
Oh yeah, a chute flap would be awesome.
I'll get some photo's up of the one I have, and if you want it, I'll send it, Otherwise I'll keep my eyes peeled for another!
Cheers Ty
Cheers Ty
Posts: 346 Likes: 3
I'd be looking where the engine cutout plug is, where the two wires go into the carb. Quite often I experienced the small chamber being wet with fuel or water, which will short out the spark. I can't remember the last time I encountered stuffed points or condensor!
Cheers.
Posts: 1,819 Likes: 6
Easy way to test that is to just pull out the cross pin wire and check for spark.
You can also make up a chute easly out of an offcut of 5" C perlin.
Id load up a pic but its not working.
Hi Mr Davis,
Sorry to take so long to get back to a reply. Yeah that chute flap doesn't look pretty but it will do you the job. I could definitely use that old chute and possibly make a new one at some point later on.
Thanks.
Maybe the uploader will work today. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2012/03/full-4181-5941-ute1_001.jpg) Must be these two pics. Try image shack. Place up the road has a machine that rolls the flat into the C perlin. I just got an off cut, i think it was 5 inch. Got some stainless hinges from a stall at the laverton market. I think i made up 3 or 4 of them out of a bit about 2 foot long. I cheated, i cut them out with the plasma cutter. You could use a grinder. Also in the picture is the height thingy with the holes in it. They split and flap around and wont hold the head of the handle bolt to do it up. I welded it too a handle mount plate for a steel base victa.
Nice job Rodeobob.
Thanks for the info and pics, will have to give that a go myself at some point.
Also, I tested the engine today and there is spark, so I guess there must be some problem with the carby.
Hey guys I have a mower just like the one in this thread but I just can't get it to start it has spark and I have just cleaned out the carby but no go. Any ideas
Hi Adrian, and a warm welcome to the forum, it's great to have you aboard.  We are lucky here, Joe Carroll, our resident Victa guru is online... I'm sure he will jump in here to give some good advice with your problem...Over to you Joe...
Hi mate, try a bit of start ya bastard that usually helps if not the needle in the carbi maybe stuck and it could be flooding itself
new to site hope this is where i put question if not i do apologise. i have a 2 stroke victa and while it is running it is making a ticking cracking sound but yet 2 runs good revs idles but just makes that noise anyone had it happen b4?? thanks
Thanks deejay for the welcome. I have been reading on the forum and I think the motor is a 160cc it has the coil on the side of the flywheel but the wires that go to the carby I'm not 100% on if anyone has a diagram. That would be great. Thanks.
new to site hope this is where i put question if not i do apologise. i have a 2 stroke victa and while it is running it is making a ticking cracking sound but yet 2 runs good revs idles but just makes that noise anyone had it happen b4?? thanks Hi there, please start a new thread in Victa 2 stroke engines and I will guide you though what might or might not be going on.
Hey guys I have a mower just like the one in this thread but I just can't get it to start it has spark and I have just cleaned out the carby but no go. Any ideas Hi there, please start a new thread in victa 2 stroke engines and I will guide you though what might or might not be going on.
I finally got around to getting the old Victa going again. The problem appears to have been the cut off pins touching. She's running again and I love it.
By the way, I bought one of those alcheapo Victa Vantage mowers from Bunnings a while back, and so far she runs pretty good. I doubt she will last as long as my old Victa but she does a fairly decent job at the moment for a cheap mower.
Posts: 4,291 Likes: 4
You went and bought what? You are a brave man.One thing I will never do is buy a new mower.The older ones are better stronger and will last longer.Good luck with the newer one though.
Members18,156
