1,963
549
Posts: 523 Likes: 1
![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2012/10/full-6043-8346-20121018_143324.jpg) I got my new vc sport home today an tryin to get her running. But iam gettin no spark i pulled the cowl off an the ignition lead runs into the block? Could there be something wrong in there or would it be something more simple?
If you disconnect the wire at the carby and it still has no spark, you will need to remove the flywheel and clean/replace the points
Posts: 523 Likes: 1
![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2012/10/full-6043-8358-20121018_173240.jpg) The wire with the red connection end?
Posts: 523 Likes: 1
Also if it is the points is that a pretty straight forward n simple job??
That would be the wire, once the flywheel is off its pretty straightforward, I use a puller on the flywheels, however other members have done it without.
Posts: 523 Likes: 1
So if im lucky i could pull flywheel off by hand an i removed that red wire an nothing still so mist be points
Posts: 1,819 Likes: 6
If it hasnt had water in the starter cup the flywheel should come off fairly easy.
Posts: 523 Likes: 1
Ok thanks ill give it a go soon. Do i just buy victa 2 stroke points
Nah, pull it appart and look first.
They might just need to be cleaned.
Thats a olden days thing. Any bloke mid 40's or older would be very well versed in cleaning points. Mid 40's to down under my age and its a dying art. Those who did do it didnt do it for enough years and have forgotten. Or got wind of the newer fangdangled electronic ignition and bought a commodore distributor to put in the old HQ so I never had to touch the points again.
Them old folks were onto something. Go chase one up that has a 'points file' in his tool box. He will be able to sort you out with a demo. Nah just joking, Im sure you will sort it out.
They could be tarnished or stuck. They might be stuffed too, but you might be able to save them.
Topics13,058
Posts107,236
Members17,805
